score
cpu
avr
avr
sfr_defs.h
1
7
/* Copyright (c) 2002, Marek Michalkiewicz <marekm@amelek.gda.pl>
8
All rights reserved.
9
10
Redistribution and use in source and binary forms, with or without
11
modification, are permitted provided that the following conditions are met:
12
13
* Redistributions of source code must retain the above copyright
14
notice, this list of conditions and the following disclaimer.
15
16
* Redistributions in binary form must reproduce the above copyright
17
notice, this list of conditions and the following disclaimer in
18
the documentation and/or other materials provided with the
19
distribution.
20
21
* Neither the name of the copyright holders nor the names of
22
contributors may be used to endorse or promote products derived
23
from this software without specific prior written permission.
24
25
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27
IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28
ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29
LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30
CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31
SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32
INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33
CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35
POSSIBILITY OF SUCH DAMAGE. */
36
37
/* avr/sfr_defs.h - macros for accessing AVR special function registers */
38
39
40
#ifndef _AVR_SFR_DEFS_H_
41
#define _AVR_SFR_DEFS_H_ 1
42
127
#ifdef __ASSEMBLER__
128
#define _SFR_ASM_COMPAT 1
129
#elif !defined(_SFR_ASM_COMPAT)
130
#define _SFR_ASM_COMPAT 0
131
#endif
132
133
#ifndef __ASSEMBLER__
134
/* These only work in C programs. */
135
#include <inttypes.h>
136
137
#define _MMIO_BYTE(mem_addr) (*(volatile uint8_t *)(mem_addr))
138
#define _MMIO_WORD(mem_addr) (*(volatile uint16_t *)(mem_addr))
139
#define _MMIO_DWORD(mem_addr) (*(volatile uint32_t *)(mem_addr))
140
#endif
141
142
#if _SFR_ASM_COMPAT
143
144
#ifndef __SFR_OFFSET
145
/* Define as 0 before including this file for compatibility with old asm
146
sources that don't subtract __SFR_OFFSET from symbolic I/O addresses. */
147
# if __AVR_ARCH__ >= 100
148
# define __SFR_OFFSET 0x00
149
# else
150
# define __SFR_OFFSET 0x20
151
# endif
152
#endif
153
154
#if (__SFR_OFFSET != 0) && (__SFR_OFFSET != 0x20)
155
#error "__SFR_OFFSET must be 0 or 0x20"
156
#endif
157
158
#define _SFR_MEM8(mem_addr) (mem_addr)
159
#define _SFR_MEM16(mem_addr) (mem_addr)
160
#define _SFR_MEM32(mem_addr) (mem_addr)
161
#define _SFR_IO8(io_addr) ((io_addr) + __SFR_OFFSET)
162
#define _SFR_IO16(io_addr) ((io_addr) + __SFR_OFFSET)
163
164
#define _SFR_IO_ADDR(sfr) ((sfr) - __SFR_OFFSET)
165
#define _SFR_MEM_ADDR(sfr) (sfr)
166
#define _SFR_IO_REG_P(sfr) ((sfr) < 0x40 + __SFR_OFFSET)
167
168
#if (__SFR_OFFSET == 0x20)
169
/* No need to use ?: operator, so works in assembler too. */
170
#define _SFR_ADDR(sfr) _SFR_MEM_ADDR(sfr)
171
#elif !defined(__ASSEMBLER__)
172
#define _SFR_ADDR(sfr) (_SFR_IO_REG_P(sfr) ? (_SFR_IO_ADDR(sfr) + 0x20) : _SFR_MEM_ADDR(sfr))
173
#endif
174
175
#else
/* !_SFR_ASM_COMPAT */
176
177
178
179
180
# else
181
182
# endif
183
#endif
184
185
#define _SFR_MEM8(mem_addr) _MMIO_BYTE(mem_addr)
186
#define _SFR_MEM16(mem_addr) _MMIO_WORD(mem_addr)
187
#define _SFR_MEM32(mem_addr) _MMIO_DWORD(mem_addr)
188
#define _SFR_IO8(io_addr) _MMIO_BYTE((io_addr) + __SFR_OFFSET)
189
#define _SFR_IO16(io_addr) _MMIO_WORD((io_addr) + __SFR_OFFSET)
190
191
#define _SFR_MEM_ADDR(sfr) ((uint16_t) &(sfr))
192
#define _SFR_IO_ADDR(sfr) (_SFR_MEM_ADDR(sfr) - __SFR_OFFSET)
193
#define _SFR_IO_REG_P(sfr) (_SFR_MEM_ADDR(sfr) < 0x40 + __SFR_OFFSET)
194
195
196
197
#endif
198
199
#define _SFR_BYTE(sfr) _MMIO_BYTE(_SFR_ADDR(sfr))
200
#define _SFR_WORD(sfr) _MMIO_WORD(_SFR_ADDR(sfr))
201
#define _SFR_DWORD(sfr) _MMIO_DWORD(_SFR_ADDR(sfr))
202
217
#define _BV(bit) (1 << (bit))
218
221
#ifndef _VECTOR
222
#define _VECTOR(N) __vector_ ## N
223
#endif
224
225
226
227
240
#define bit_is_set(sfr, bit) (_SFR_BYTE(sfr) & _BV(bit))
241
250
#define bit_is_clear(sfr, bit) (!(_SFR_BYTE(sfr) & _BV(bit)))
251
257
#define loop_until_bit_is_set(sfr, bit) do { } while (bit_is_clear(sfr, bit))
258
264
#define loop_until_bit_is_clear(sfr, bit) do { } while (bit_is_set(sfr, bit))
265
270
#endif
/* !__ASSEMBLER__ */
271
272
#endif
/* _SFR_DEFS_H_ */
