cpu.h File Reference
#include <rtems/score/types.h>
#include <rtems/score/sh.h>
Include dependency graph for cpu.h:
struct  Context_Control
 This defines the minimal set of integer and processor state registers that must be saved during a voluntary context switch from one thread to another. More...
struct  Context_Control_fp
 This defines the complete set of floating point registers that must be saved during any context switch from one thread to another. More...
struct  CPU_Interrupt_frame
 This defines the set of integer and processor state registers that must be saved during an interrupt. More...
#define CPU_INLINE_ENABLE_DISPATCH   FALSE
#define CPU_SIMPLE_VECTORED_INTERRUPTS   TRUE
#define CPU_HAS_SOFTWARE_INTERRUPT_STACK   TRUE
#define CPU_HAS_HARDWARE_INTERRUPT_STACK   FALSE
#define CPU_ALLOCATE_INTERRUPT_STACK   FALSE
#define CPU_ISR_PASSES_FRAME_POINTER   0
#define CPU_SOFTWARE_FP   FALSE
#define CPU_HARDWARE_FP   FALSE
#define CPU_ALL_TASKS_ARE_FP   FALSE
#define CPU_IDLE_TASK_IS_FP   FALSE
#define CPU_USE_DEFERRED_FP_SWITCH   TRUE
#define CPU_PROVIDES_IDLE_THREAD_BODY   TRUE
#define CPU_STACK_GROWS_UP   FALSE
#define CPU_STRUCTURE_ALIGNMENT   __attribute__ ((aligned(16)))
#define CPU_TIMESTAMP_USE_INT64_INLINE   TRUE
#define CPU_BIG_ENDIAN   TRUE
#define CPU_LITTLE_ENDIAN   FALSE
#define CPU_MODES_INTERRUPT_MASK   0x0000000f
#define CPU_PER_CPU_CONTROL_SIZE   0
#define _CPU_Context_Get_SP(_context)   (_context)->r15
#define CPU_CONTEXT_FP_SIZE   sizeof( Context_Control_fp )
#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK   0
#define CPU_INTERRUPT_NUMBER_OF_VECTORS   256
#define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER   (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1)
#define CPU_PROVIDES_ISR_IS_IN_PROGRESS   FALSE
#define CPU_STACK_MINIMUM_SIZE   4096
#define CPU_SIZEOF_POINTER   4
#define CPU_ALIGNMENT   4
#define CPU_HEAP_ALIGNMENT   CPU_ALIGNMENT
#define CPU_PARTITION_ALIGNMENT   CPU_ALIGNMENT
#define CPU_STACK_ALIGNMENT   CPU_ALIGNMENT
#define _CPU_Initialize_vectors()
#define _CPU_ISR_Disable(_level)   sh_disable_interrupts( _level )
#define _CPU_ISR_Enable(_level)   sh_enable_interrupts( _level)
#define _CPU_ISR_Flash(_level)   sh_flash_interrupts( _level)
#define _CPU_ISR_Set_level(_newlevel)   sh_set_interrupt_level(_newlevel)
#define _CPU_Context_Restart_self(_the_context)   _CPU_Context_restore( (_the_context) );
#define _CPU_Context_Fp_start(_base, _offset)   ( (void *) _Addresses_Add_offset( (_base), (_offset) ) )
#define _CPU_Context_Initialize_fp(_destination)   { }
#define _CPU_Fatal_halt(_source, _error)
#define CPU_USE_GENERIC_BITFIELD_CODE   TRUE
#define CPU_USE_GENERIC_BITFIELD_DATA   TRUE
#define _CPU_Bitfield_Find_first_bit(_value, _output)
#define _CPU_Priority_Mask(_bit_number)   ( 1 << (_bit_number) )
#define _CPU_Priority_bits_index(_priority)   (_priority)
typedef CPU_Interrupt_frame CPU_Exception_frame
typedef uint32_t CPU_Counter_ticks
SCORE_EXTERN void CPU_delay (uint32_t microseconds)
uint32_t _CPU_ISR_Get_level (void)
 Return the current interrupt disable level for this task in the format used by the interrupt level portion of the task mode. More...
SCORE_EXTERN void _CPU_Context_Initialize (Context_Control *_the_context, void *_stack_base, uint32_t _size, uint32_t _isr, void(*_entry_point)(void), int _is_fp, void *_tls_area)
void _CPU_Initialize (void)
 CPU initialization. More...
void _CPU_ISR_install_raw_handler (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler)
 This routine installs a "raw" interrupt handler directly into the processor's vector table. More...
void _CPU_ISR_install_vector (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler)
 This routine installs an interrupt vector. More...
void _CPU_Install_interrupt_stack (void)
 This routine installs the hardware interrupt stack pointer. More...
void * _CPU_Thread_Idle_body (uintptr_t ignored)
 This routine is the CPU dependent IDLE thread body. More...
void _CPU_Context_switch (Context_Control *run, Context_Control *heir)
 CPU switch context. More...
void _CPU_Context_restore (Context_Control *new_context)
 This routine is generally used only to restart self in an efficient manner. More...
void _CPU_Context_save_fp (Context_Control_fp **fp_context_ptr)
 This routine saves the floating point context passed to it. More...
void _CPU_Context_restore_fp (Context_Control_fp **fp_context_ptr)
 This routine restores the floating point context passed to it. More...
void _CPU_Exception_frame_print (const CPU_Exception_frame *frame)
 Prints the exception frame via printk(). More...
CPU_Counter_ticks _CPU_Counter_read (void)
 Returns the current CPU counter value. More...
uint8_t _bit_set_table []
◆ _CPU_Bitfield_Find_first_bit
#define _CPU_Bitfield_Find_first_bit (   _value,
  _output
Value:
_output = 0;\
if(_value > 0x00ff) \
{ _value >>= 8; _output = 8; } \
if(_value > 0x000f) \
{ _output += 4; _value >>= 4; } \
_output += _bit_set_table[ _value]; }
◆ _CPU_Fatal_halt
#define _CPU_Fatal_halt (   _source,
  _error
Value:
__asm__ volatile("mov.l %0,r0"::"m" (_error)); \
__asm__ volatile("mov #1, r4"); \
__asm__ volatile("trapa #34"); \
