Hitachi H8300 CPU Department Source. More...
struct | CPU_Per_CPU_control |
The CPU specific per-CPU control. More... | |
struct | Context_Control |
This defines the minimal set of integer and processor state registers that must be saved during a voluntary context switch from one thread to another. More... | |
struct | Context_Control_fp |
This defines the complete set of floating point registers that must be saved during any context switch from one thread to another. More... | |
struct | CPU_Interrupt_frame |
This defines the set of integer and processor state registers that must be saved during an interrupt. More... | |
#define | CPU_INLINE_ENABLE_DISPATCH FALSE |
#define | RTEMS_USE_16_BIT_OBJECT |
#define | CPU_HAS_SOFTWARE_INTERRUPT_STACK TRUE |
#define | CPU_SIMPLE_VECTORED_INTERRUPTS TRUE |
#define | CPU_HAS_HARDWARE_INTERRUPT_STACK FALSE |
#define | CPU_ALLOCATE_INTERRUPT_STACK TRUE |
#define | CPU_HARDWARE_FP FALSE |
#define | CPU_ALL_TASKS_ARE_FP FALSE |
#define | CPU_IDLE_TASK_IS_FP FALSE |
#define | CPU_USE_DEFERRED_FP_SWITCH TRUE |
#define | CPU_PROVIDES_IDLE_THREAD_BODY FALSE |
#define | CPU_STACK_GROWS_UP FALSE |
#define | CPU_STRUCTURE_ALIGNMENT |
#define | CPU_TIMESTAMP_USE_STRUCT_TIMESPEC TRUE |
#define | CPU_BIG_ENDIAN TRUE |
#define | CPU_LITTLE_ENDIAN FALSE |
#define | CPU_MODES_INTERRUPT_MASK 0x00000001 |
#define | CPU_PER_CPU_CONTROL_SIZE 0 |
#define | nogap __attribute__ ((packed)) |
#define | _CPU_Context_Get_SP(_context) (_context)->er7 |
#define | CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp ) |
#define | CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0 |
#define | CPU_INTERRUPT_NUMBER_OF_VECTORS 64 |
#define | CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1) |
#define | CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE |
#define | CPU_STACK_MINIMUM_SIZE (1536) |
#define | CPU_SIZEOF_POINTER 2 |
#define | CPU_ALIGNMENT 8 |
#define | CPU_HEAP_ALIGNMENT CPU_ALIGNMENT |
#define | CPU_PARTITION_ALIGNMENT CPU_ALIGNMENT |
#define | CPU_STACK_ALIGNMENT 2 |
#define | _CPU_Initialize_vectors() |
#define | _CPU_ISR_Disable(_isr_cookie) |
#define | _CPU_ISR_Enable(_isr_cookie) |
#define | _CPU_ISR_Flash(_isr_cookie) |
#define | _CPU_ISR_Set_level(_new_level) |
#define | CPU_CCR_INTERRUPTS_ON 0x80 |
#define | CPU_CCR_INTERRUPTS_OFF 0x00 |
#define | _CPU_Context_Initialize(_the_context, _stack_base, _size, _isr, _entry_point, _is_fp, _tls_area) |
#define | _CPU_Context_Restart_self(_the_context) _CPU_Context_restore( (_the_context) ); |
#define | _CPU_Context_Fp_start(_base, _offset) ( (void *) (_base) + (_offset) ) |
#define | _CPU_Context_Initialize_fp(_destination) |
#define | _CPU_Fatal_halt(_source, _error) |
#define | CPU_USE_GENERIC_BITFIELD_CODE TRUE |
#define | CPU_USE_GENERIC_BITFIELD_DATA TRUE |
#define | _CPU_Bitfield_Find_first_bit(_value, _output) |
#define | _CPU_Priority_Mask(_bit_number) ( 1 << (_bit_number) ) |
#define | _CPU_Priority_bits_index(_priority) (_priority) |
#define | CPU_swap_u16(value) (((value&0xff) << 8) | ((value >> 8)&0xff)) |
Typedefs | |
typedef CPU_Interrupt_frame | CPU_Exception_frame |
typedef uint32_t | CPU_Counter_ticks |
uint32_t | _CPU_ISR_Get_level (void) |
Return the current interrupt disable level for this task in the format used by the interrupt level portion of the task mode. More... | |
void | _CPU_Initialize (void) |
CPU initialization. More... | |
void | _CPU_ISR_install_raw_handler (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler) |
This routine installs a "raw" interrupt handler directly into the processor's vector table. More... | |
void | _CPU_ISR_install_vector (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler) |
This routine installs an interrupt vector. More... | |
void | _CPU_Install_interrupt_stack (void) |
This routine installs the hardware interrupt stack pointer. More... | |
void * | _CPU_Thread_Idle_body (uint32_t) |
void | _CPU_Context_switch (Context_Control *run, Context_Control *heir) |
CPU switch context. More... | |
void | _CPU_Context_restore (Context_Control *new_context) |
This routine is generally used only to restart self in an efficient manner. More... | |
void | _CPU_Context_save_fp (Context_Control_fp **fp_context_ptr) |
This routine saves the floating point context passed to it. More... | |
void | _CPU_Context_restore_fp (Context_Control_fp **fp_context_ptr) |
This routine restores the floating point context passed to it. More... | |
void | _CPU_Exception_frame_print (const CPU_Exception_frame *frame) |
Prints the exception frame via printk(). More... | |
CPU_Counter_ticks | _CPU_Counter_read (void) |
void | H8BD_Install_IRQ (uint32_t vector, proc_ptr new_handler, proc_ptr *old_handler) |
SCORE_EXTERN Context_Control_fp | _CPU_Null_fp_context |
This include file contains information pertaining to the H8300 processor.
#define _CPU_Bitfield_Find_first_bit | ( | _value, | |
_output | |||
#define _CPU_Context_Initialize | ( | _the_context, | |
_stack_base, | |||
_size, | |||
_isr, | |||
_entry_point, | |||
_is_fp, | |||
_tls_area | |||
#define _CPU_Context_Initialize_fp | ( | _destination | ) |
#define _CPU_Fatal_halt | ( | _source, | |
_error | |||
#define _CPU_ISR_Disable | ( | _isr_cookie | ) |
#define _CPU_ISR_Enable | ( | _isr_cookie | ) |
#define _CPU_ISR_Flash | ( | _isr_cookie | ) |
#define _CPU_ISR_Set_level | ( | _new_level | ) |
