score
cpu
no_cpu
asm.h
1
16
17
* COPYRIGHT:
18
19
* This file is based on similar code found in newlib available
20
* from ftp.cygnus.com. The file which was used had no copyright
21
* notice. This file is freely distributable as long as the source
22
* of the file is noted. This file is:
23
24
* COPYRIGHT (c) 1994-2006.
25
* On-Line Applications Research Corporation (OAR).
26
27
28
#ifndef _RTEMS_ASM_H
29
#define _RTEMS_ASM_H
30
38
39
* Indicate we are in an assembly file and get the basic CPU definitions.
40
41
42
#ifndef ASM
43
#define ASM
44
#endif
45
46
rtems/score/no_cpu.h
47
48
#ifndef __USER_LABEL_PREFIX__
49
57
#define __USER_LABEL_PREFIX__ _
58
#endif
59
60
#ifndef __REGISTER_PREFIX__
61
69
#define __REGISTER_PREFIX__
70
#endif
71
72
rtems/concat.h
73
75
#define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
76
78
#define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
79
80
81
* define macros for all of the registers on this CPU
82
83
* EXAMPLE: #define d0 REG (d0)
84
85
86
87
* Define macros to handle section beginning and ends.
88
89
90
92
#define BEGIN_CODE_DCL .text
93
94
#define END_CODE_DCL
95
96
#define BEGIN_DATA_DCL .data
97
98
#define END_DATA_DCL
99
100
#define BEGIN_CODE .text
101
102
#define END_CODE
103
104
#define BEGIN_DATA
105
106
#define END_DATA
107
110
#define BEGIN_BSS
111
112
#define END_BSS
113
114
#define END
115
122
#define PUBLIC(sym) .globl SYM (sym)
123
130
#define EXTERN(sym) .globl SYM (sym)
131
133
#endif
no_cpu.h
concat.h
This include file defines ANSI concatenation macros.
