| rtems_status_code | rtems_message_queue_create (rtems_name name, uint32_t count, size_t max_message_size, rtems_attribute attribute_set, rtems_id *id) |
| | RTEMS Create Message Queue. More...
| rtems_status_code | rtems_message_queue_ident (rtems_name name, uint32_t node, rtems_id *id) |
| | RTEMS Message Queue Name to Id. More...
| rtems_status_code | rtems_message_queue_delete (rtems_id id) |
| | RTEMS Delete Message Queue. More...
| rtems_status_code | rtems_message_queue_send (rtems_id id, const void *buffer, size_t size) |
| | rtems_message_queue_send More...
| rtems_status_code | rtems_message_queue_urgent (rtems_id id, const void *buffer, size_t size) |
| | RTEMS Urgent Message Queue. More...
| rtems_status_code | rtems_message_queue_broadcast (rtems_id id, const void *buffer, size_t size, uint32_t *count) |
| | RTEMS Broadcast Message Queue. More...
| rtems_status_code | rtems_message_queue_receive (rtems_id id, void *buffer, size_t *size, rtems_option option_set, rtems_interval timeout) |
| | RTEMS Message Queue Receive. More...
| rtems_status_code | rtems_message_queue_flush (rtems_id id, uint32_t *count) |
| | rtems_message_queue_flush More...
| rtems_status_code | rtems_message_queue_get_number_pending (rtems_id id, uint32_t *count) |
| | RTEMS Message Queue Get Number Pending. More...
