#define | KMEMSTATS |
#define | M_WAITOK 0x0000 |
#define | M_NOWAIT 0x0001 |
#define | M_KERNEL 0x0002 |
#define | M_FREE 0 /* should be on free list */ |
#define | M_MBUF 1 /* mbuf */ |
#define | M_DEVBUF 2 /* device driver memory */ |
#define | M_SOCKET 3 /* socket structure */ |
#define | M_PCB 4 /* protocol control block */ |
#define | M_RTABLE 5 /* routing tables */ |
#define | M_HTABLE 6 /* IMP host tables */ |
#define | M_FTABLE 7 /* fragment reassembly header */ |
#define | M_ZOMBIE 8 /* zombie proc status */ |
#define | M_IFADDR 9 /* interface address */ |
#define | M_SOOPTS 10 /* socket options */ |
#define | M_SONAME 11 /* socket name */ |
#define | M_NAMEI 12 /* namei path name buffer */ |
#define | M_GPROF 13 /* kernel profiling buffer */ |
#define | M_IOCTLOPS 14 /* ioctl data buffer */ |
#define | M_MAPMEM 15 /* mapped memory descriptors */ |
#define | M_CRED 16 /* credentials */ |
#define | M_PGRP 17 /* process group header */ |
#define | M_SESSION 18 /* session header */ |
#define | M_IOV 19 /* large iov's */ |
#define | M_MOUNT 20 /* vfs mount struct */ |
#define | M_FHANDLE 21 /* network file handle */ |
#define | M_NFSREQ 22 /* NFS request header */ |
#define | M_NFSMNT 23 /* NFS mount structure */ |
#define | M_NFSNODE 24 /* NFS vnode private part */ |
#define | M_VNODE 25 /* Dynamically allocated vnodes */ |
#define | M_CACHE 26 /* Dynamically allocated cache entries */ |
#define | M_DQUOT 27 /* UFS quota entries */ |
#define | M_UFSMNT 28 /* UFS mount structure */ |
#define | M_SHM 29 /* SVID compatible shared memory segments */ |
#define | M_VMMAP 30 /* VM map structures */ |
#define | M_VMMAPENT 31 /* VM map entry structures */ |
#define | M_VMOBJ 32 /* VM object structure */ |
#define | M_VMOBJHASH 33 /* VM object hash structure */ |
#define | M_VMPMAP 34 /* VM pmap */ |
#define | M_VMPVENT 35 /* VM phys-virt mapping entry */ |
#define | M_VMPAGER 36 /* XXX: VM pager struct */ |
#define | M_VMPGDATA 37 /* XXX: VM pager private data */ |
#define | M_FILE 38 /* Open file structure */ |
#define | M_FILEDESC 39 /* Open file descriptor table */ |
#define | M_LOCKF 40 /* Byte-range locking structures */ |
#define | M_PROC 41 /* Proc structures */ |
#define | M_SUBPROC 42 /* Proc sub-structures */ |
#define | M_SEGMENT 43 /* Segment for LFS */ |
#define | M_LFSNODE 44 /* LFS vnode private part */ |
#define | M_FFSNODE 45 /* FFS vnode private part */ |
#define | M_MFSNODE 46 /* MFS vnode private part */ |
#define | M_NQLEASE 47 /* Nqnfs lease */ |
#define | M_NQMHOST 48 /* Nqnfs host address table */ |
#define | M_NETADDR 49 /* Export host address structure */ |
#define | M_NFSSVC 50 /* Nfs server structure */ |
#define | M_NFSUID 51 /* Nfs uid mapping structure */ |
#define | M_NFSD 52 /* Nfs server daemon structure */ |
#define | M_IPMOPTS 53 /* internet multicast options */ |
#define | M_IPMADDR 54 /* internet multicast address */ |
#define | M_IFMADDR 55 /* link-level multicast address */ |
#define | M_MRTABLE 56 /* multicast routing tables */ |
#define | M_ISOFSMNT 57 /* ISOFS mount structure */ |
#define | M_ISOFSNODE 58 /* ISOFS vnode private part */ |
#define | M_NFSRVDESC 59 /* NFS server socket descriptor */ |
#define | M_NFSDIROFF 60 /* NFS directory offset data */ |
#define | M_NFSBIGFH 61 /* NFS version 3 file handle */ |
#define | M_MSDOSFSMNT 67 /* MSDOSFS mount structure */ |
#define | M_MSDOSFSNODE 68 /* MSDOSFS vnode private part */ |
#define | M_MSDOSFSFAT 69 /* MSDOSFS file allocation table */ |
#define | M_DEVFSMNT 70 /* DEVFS mount structure */ |
#define | M_DEVFSBACK 71 /* DEVFS Back node */ |
#define | M_DEVFSFRONT 72 /* DEVFS Front node */ |
#define | M_DEVFSNODE 73 /* DEVFS node */ |
#define | M_TEMP 74 /* misc temporary data buffers */ |
#define | M_TTYS 75 /* tty data structures */ |
#define | M_GZIP 76 /* Gzip trees */ |
#define | M_IPFW 77 /* IpFw/IpAcct chain's */ |
#define | M_DEVL 78 /* isa_device lists in userconfig() */ |
#define | M_PKTCLASS 79 /* structures used in packet classifier */ |
#define | M_SYSCTL 80 /* sysctl internal magic */ |
#define | M_SECA 81 /* security associations, key management */ |
#define | M_BIOBUF 82 /* BIO buffer */ |
#define | M_KTRACE 83 /* KTRACE */ |
#define | M_SELECT 84 /* select() buffer */ |
#define | M_CFS 85 /* Coda */ |
#define | M_LAST 86 /* Must be last type + 1 */ |
#define | INITKMEMNAMES |
#define | ku_freecnt ku_un.freecnt |
#define | ku_pagecnt ku_un.pagecnt |
