pppd
lcp.h
1
2
* lcp.h - Link Control Protocol definitions.
3
4
* Copyright (c) 1989 Carnegie Mellon University.
5
* All rights reserved.
6
7
* Redistribution and use in source and binary forms are permitted
8
* provided that the above copyright notice and this paragraph are
9
* duplicated in all such forms and that any documentation,
10
* advertising materials, and other materials related to such
11
* distribution and use acknowledge that the software was developed
12
* by Carnegie Mellon University. The name of the
13
* University may not be used to endorse or promote products derived
14
* from this software without specific prior written permission.
15
* THIS SOFTWARE IS PROVIDED ``AS IS'' AND WITHOUT ANY EXPRESS OR
16
* IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
17
* WARRANTIES OF MERCHANTIBILITY AND FITNESS FOR A PARTICULAR PURPOSE.
18
19
* $Id$
20
21
22
23
* Options.
24
25
#define CI_MRU 1
/* Maximum Receive Unit */
26
#define CI_ASYNCMAP 2
/* Async Control Character Map */
27
#define CI_AUTHTYPE 3
/* Authentication Type */
28
#define CI_QUALITY 4
/* Quality Protocol */
29
#define CI_MAGICNUMBER 5
/* Magic Number */
30
#define CI_PCOMPRESSION 7
/* Protocol Field Compression */
31
#define CI_ACCOMPRESSION 8
/* Address/Control Field Compression */
32
#define CI_CALLBACK 13
/* callback */
33
34
35
* LCP-specific packet types.
36
37
#define PROTREJ 8
/* Protocol Reject */
38
#define ECHOREQ 9
/* Echo Request */
39
#define ECHOREP 10
/* Echo Reply */
40
#define DISCREQ 11
/* Discard Request */
41
#define CBCP_OPT 6
/* Use callback control protocol */
42
43
44
* The state of options is described by an lcp_options structure.
45
46
typedef
struct
lcp_options
47
bool
passive;
/* Don't die if we don't get a response */
48
bool
silent;
/* Wait for the other end to start first */
49
bool
restart;
/* Restart vs. exit after close */
50
bool
neg_mru;
/* Negotiate the MRU? */
51
bool
neg_asyncmap;
/* Negotiate the async map? */
52
bool
neg_upap;
/* Ask for UPAP authentication? */
53
bool
neg_chap;
/* Ask for CHAP authentication? */
54
bool
neg_magicnumber;
/* Ask for magic number? */
55
bool
neg_pcompression;
/* HDLC Protocol Field Compression? */
56
bool
neg_accompression;
/* HDLC Address/Control Field Compression? */
57
bool
neg_lqr;
/* Negotiate use of Link Quality Reports */
58
bool
neg_cbcp;
/* Negotiate use of CBCP */
59
int
mru;
/* Value of MRU */
60
u_char chap_mdtype;
/* which MD type (hashing algorithm) */
61
uint32_t asyncmap;
/* Value of async map */
62
uint32_t magicnumber;
63
int
numloops;
/* Number of loops during magic number neg. */
64
uint32_t lqr_period;
/* Reporting period for LQR 1/100ths second */
65
lcp_options
66
67
extern
fsm
lcp_fsm[];
68
extern
lcp_options
lcp_wantoptions[];
69
extern
lcp_options
lcp_gotoptions[];
70
extern
lcp_options
lcp_allowoptions[];
71
extern
lcp_options
lcp_hisoptions[];
72
extern
uint32_t xmit_accm[][8];
73
74
#define DEFMRU 1500
/* Try for this */
75
#define MINMRU 128
/* No MRUs below this */
76
#define MAXMRU 16384
/* Normally limit MRU to this */
77
78
void
lcp_open(
int
79
void
lcp_close(
int
char
80
void
lcp_lowerup(
int
81
void
lcp_lowerdown(
int
82
void
lcp_sprotrej(
int
, u_char *,
int
/* send protocol reject */
83
84
extern
struct
protent
lcp_protent;
85
86
/* Default number of times we receive our magic number from the peer
87
before deciding the link is looped-back. */
88
#define DEFLOOPBACKFAIL 10
fsm
Definition:
fsm.h:44
protent
Definition:
pppd.h:250
lcp_options
Definition:
lcp.h:47
