score
include
score
isrlevel.h
1
10
11
* COPYRIGHT (c) 1989-2011.
12
* On-Line Applications Research Corporation (OAR).
13
14
* The license and distribution terms for this file may be
15
* found in the file LICENSE in this distribution or at
16
* http://www.rtems.org/license/LICENSE.
17
18
19
#ifndef _RTEMS_SCORE_ISR_LEVEL_h
20
#define _RTEMS_SCORE_ISR_LEVEL_h
21
22
#include <rtems/score/cpu.h>
23
rtems/score/assert.h
24
25
#ifdef __cplusplus
26
extern
"C"
27
#endif
28
42
typedef
uint32_t
ISR_Level
43
58
#define _ISR_Disable( _level ) \
59
do { \
60
_CPU_ISR_Disable( _level ); \
61
_Assert( _Debug_Is_owner_of_giant() ); \
62
RTEMS_COMPILER_MEMORY_BARRIER(); \
63
} while (0)
64
76
#define _ISR_Enable( _level ) \
77
do { \
78
79
80
_CPU_ISR_Enable( _level ); \
81
} while (0)
82
102
#define _ISR_Flash( _level ) \
103
do { \
104
105
106
_CPU_ISR_Flash( _level ); \
107
108
} while (0)
109
120
#define _ISR_Get_level() \
121
_CPU_ISR_Get_level()
122
132
#define _ISR_Set_level( _new_level ) \
133
do { \
134
135
_CPU_ISR_Set_level( _new_level ); \
136
137
} while (0)
138
139
#define _ISR_Disable_without_giant( _level ) \
140
do { \
141
142
143
} while (0)
144
145
#define _ISR_Enable_without_giant( _level ) \
146
do { \
147
148
149
} while (0)
150
153
#ifdef __cplusplus
154
155
#endif
156
#endif
assert.h
ISR_Level
uint32_t ISR_Level
The following type defines the control block used to manage the interrupt level portion of the status...
Definition:
isrlevel.h:42
