#define | _AVR_IOXXX_H_ "iotn11.h" |
#define | ACSR _SFR_IO8(0x08) |
#define | PINB _SFR_IO8(0x16) |
#define | DDRB _SFR_IO8(0x17) |
#define | PORTB _SFR_IO8(0x18) |
#define | WDTCR _SFR_IO8(0x21) |
#define | TCNT0 _SFR_IO8(0x32) |
#define | TCCR0 _SFR_IO8(0x33) |
#define | MCUSR _SFR_IO8(0x34) |
#define | MCUCR _SFR_IO8(0x35) |
#define | TIFR _SFR_IO8(0x38) |
#define | TIMSK _SFR_IO8(0x39) |
#define | GIFR _SFR_IO8(0x3A) |
#define | GIMSK _SFR_IO8(0x3B) |
#define | INT0_vect _VECTOR(1) |
#define | SIG_INTERRUPT0 _VECTOR(1) |
#define | IO_PINS_vect _VECTOR(2) |
#define | SIG_PIN _VECTOR(2) |
#define | SIG_PIN_CHANGE _VECTOR(2) |
#define | TIMER0_OVF_vect _VECTOR(3) |
#define | SIG_OVERFLOW0 _VECTOR(3) |
#define | ANA_COMP_vect _VECTOR(4) |
#define | SIG_COMPARATOR _VECTOR(4) |
#define | _VECTORS_SIZE 10 |
#define | INT0 6 |
#define | PCIE 5 |
#define | INTF0 6 |
#define | PCIF 5 |
#define | TOIE0 1 |
#define | TOV0 1 |
#define | SE 5 |
#define | SM 4 |
#define | ISC01 1 |
#define | ISC00 0 |
#define | CS02 2 |
#define | CS01 1 |
#define | CS00 0 |
#define | WDTOE 4 |
#define | WDE 3 |
#define | WDP2 2 |
#define | WDP1 1 |
#define | WDP0 0 |
#define | PB4 4 |
#define | PB3 3 |
#define | PB2 2 |
#define | PB1 1 |
#define | PB0 0 |
#define | DDB4 4 |
#define | DDB3 3 |
#define | DDB2 2 |
#define | DDB1 1 |
#define | DDB0 0 |
#define | PINB5 5 |
#define | PINB4 4 |
#define | PINB3 3 |
#define | PINB2 2 |
#define | PINB1 1 |
#define | PINB0 0 |
#define | ACD 7 |
#define | ACO 5 |
#define | ACI 4 |
#define | ACIE 3 |
#define | ACIS1 1 |
#define | ACIS0 0 |
#define | RAMEND 0x1F |
#define | XRAMEND 0x0 |
#define | E2END 0x0 |
#define | E2PAGESIZE 2 |
#define | FLASHEND 0x3FF |
#define | FUSE_MEMORY_SIZE 1 |
#define | FUSE_CKSEL0 (unsigned char)~_BV(0) |
#define | FUSE_CKSEL1 (unsigned char)~_BV(1) |
#define | FUSE_CKSEL2 (unsigned char)~_BV(2) |
#define | FUSE_RSTDISBL (unsigned char)~_BV(3) |
#define | FUSE_FSTRT (unsigned char)~_BV(4) |
#define | FUSE_DEFAULT (FUSE_CKSEL0 & FUSE_CKSEL1) |
#define | __LOCK_BITS_EXIST |
#define | SIGNATURE_0 0x1E |
#define | SIGNATURE_1 0x90 |
#define | SIGNATURE_2 0x04 |
