libmisc
fb
fb.h
1
9
10
* Copyright (c) 2000 - Rosimildo da Silva
11
12
13
#ifndef _MW_FB_H
14
#define _MW_FB_H
15
16
#include <stdint.h>
17
25
#ifdef __cplusplus
26
extern
"C"
27
#endif
28
29
/* ioctls
30
0x46 is 'F' */
31
#define FBIOGET_VSCREENINFO 0x4600
32
#define FBIOPUT_VSCREENINFO 0x4601
33
#define FBIOGET_FSCREENINFO 0x4602
34
#define FBIOGETCMAP 0x4604
35
#define FBIOPUTCMAP 0x4605
36
#define FB_EXEC_FUNCTION 0x4606
37
#define FBIOSWAPBUFFERS 0x4607
38
#define FBIOSETBUFFERMODE 0x4608
39
#define FBIOSETVIDEOMODE 0x4609
40
41
#define FB_SINGLE_BUFFERED 0
42
#define FB_TRIPLE_BUFFERED 1
43
44
#define FB_TYPE_PACKED_PIXELS 0
/* Packed Pixels */
45
#define FB_TYPE_PLANES 1
/* Non interleaved planes */
46
#define FB_TYPE_INTERLEAVED_PLANES 2
/* Interleaved planes */
47
#define FB_TYPE_TEXT 3
/* Text/attributes */
48
#define FB_TYPE_VGA_PLANES 4
/* EGA/VGA planes */
49
#define FB_TYPE_VIRTUAL_BUFFER 5
/* Virtual Buffer */
50
51
52
#define FB_VISUAL_MONO01 0
/* Monochr. 1=Black 0=White */
53
#define FB_VISUAL_MONO10 1
/* Monochr. 1=White 0=Black */
54
#define FB_VISUAL_TRUECOLOR 2
/* True color */
55
#define FB_VISUAL_PSEUDOCOLOR 3
/* Pseudo color (like atari) */
56
#define FB_VISUAL_DIRECTCOLOR 4
/* Direct color */
57
#define FB_VISUAL_STATIC_PSEUDOCOLOR 5
/* Pseudo color readonly */
58
59
#define FB_ACCEL_NONE 0
/* no hardware accelerator */
60
61
struct
fb_bitfield
62
uint32_t offset;
/* beginning of bitfield */
63
uint32_t length;
/* length of bitfield */
64
uint32_t msb_right;
/* != 0 : Most significant bit is */
65
/* right */
66
67
68
struct
fb_var_screeninfo
69
uint32_t xres;
/* visible resolution */
70
uint32_t yres;
71
uint32_t bits_per_pixel;
/* guess what */
72
struct
fb_bitfield
red;
/* bitfield in fb mem if true color, */
73
struct
fb_bitfield
green;
/* else only length is significant */
74
struct
fb_bitfield
blue;
75
struct
fb_bitfield
transp;
/* transparency */
76
77
78
struct
fb_fix_screeninfo
79
volatile
char
*smem_start;
/* Start of frame buffer mem */
80
/* (physical address) */
81
uint32_t smem_len;
/* Length of frame buffer mem */
82
uint32_t type;
/* see FB_TYPE_* */
83
uint32_t visual;
/* see FB_VISUAL_* */
84
uint32_t line_length;
/* number of chars per line */
85
86
87
struct
fb_cmap
88
uint32_t start;
/* First entry */
89
uint32_t len;
/* Number of entries */
90
uint16_t *red;
/* Red values */
91
uint16_t *green;
92
uint16_t *blue;
93
uint16_t *transp;
/* transparency, can be NULL */
94
95
96
#ifdef __cplusplus
97
98
#endif
99
101
#endif
/* _MW_FB_H */
fb_var_screeninfo
Definition:
fb.h:68
fb_bitfield
Definition:
fb.h:61
fb_cmap
Definition:
fb.h:87
fb_fix_screeninfo
Definition:
fb.h:78
