#define | NO_PRINT 1 |
#define | major(d) rtems_filesystem_dev_major_t(d) |
#define | minor(d) rtems_filesystem_dev_minor_t(d) |
#define | blocksize globals->blocksize |
#define | termwidth globals->termwidth |
#define | sortkey globals->sortkey |
#define | rval globals->rval |
#define | output globals->output |
#define | now globals->now |
#define | f_accesstime globals->f_accesstime |
#define | f_column globals->f_column |
#define | f_columnacross globals->f_columnacross |
#define | f_flags globals->f_flags |
#define | f_grouponly globals->f_grouponly |
#define | f_humanize globals->f_humanize |
#define | f_inode globals->f_inode |
#define | f_listdir globals->f_listdir |
#define | f_listdot globals->f_listdot |
#define | f_longform globals->f_longform |
#define | f_nonprint globals->f_nonprint |
#define | f_nosort globals->f_nosort |
#define | f_numericonly globals->f_numericonly |
#define | f_octal globals->f_octal |
#define | f_octal_escape globals->f_octal_escape |
#define | f_recursive globals->f_recursive |
#define | f_reversesort globals->f_reversesort |
#define | f_sectime globals->f_sectime |
#define | f_singlecol globals->f_singlecol |
#define | f_size globals->f_size |
#define | f_statustime globals->f_statustime |
#define | f_stream globals->f_stream |
#define | f_type globals->f_type |
#define | f_typedir globals->f_typedir |
#define | f_whiteout globals->f_whiteout |
#define | exit_jump &(globals->exit_jmp) |
#define | exit(ec) rtems_shell_ls_exit(globals, ec) |
#define | acccmp rtems_shell_ls_acccmp |
#define | revacccmp rtems_shell_ls_revacccmp |
#define | modcmp rtems_shell_ls_modcmp |
#define | revmodcmp rtems_shell_ls_revmodcmp |
#define | namecmp rtems_shell_ls_namecmp |
#define | revnamecmp rtems_shell_ls_revnamecmp |
#define | statcmp rtems_shell_ls_statcmp |
#define | revstatcmp rtems_shell_ls_revstatcmp |
#define | sizecmp rtems_shell_ls_sizecmp |
#define | revsizecmp rtems_shell_ls_revsizecmp |
#define | printescaped rtems_shell_ls_printescaped |
#define | printacol rtems_shell_ls_printacol |
#define | printcol rtems_shell_ls_printcol |
#define | printlong rtems_shell_ls_printlong |
#define | printscol rtems_shell_ls_printscol |
#define | printstream rtems_shell_ls_printstream |
#define | usage rtems_shell_ls_usage |
const char * | user_from_uid (uid_t uid, int nouser) |
void | rtems_shell_ls_exit (rtems_shell_ls_globals *globals, int code) |
int | acccmp (const FTSENT *, const FTSENT *) |
int | revacccmp (const FTSENT *, const FTSENT *) |
int | modcmp (const FTSENT *, const FTSENT *) |
int | revmodcmp (const FTSENT *, const FTSENT *) |
int | namecmp (const FTSENT *, const FTSENT *) |
int | revnamecmp (const FTSENT *, const FTSENT *) |
int | statcmp (const FTSENT *, const FTSENT *) |
int | revstatcmp (const FTSENT *, const FTSENT *) |
int | sizecmp (const FTSENT *, const FTSENT *) |
int | revsizecmp (const FTSENT *, const FTSENT *) |
int | printescaped (rtems_shell_ls_globals *globals, const char *) |
void | printacol (rtems_shell_ls_globals *globals, DISPLAY *) |
void | printcol (rtems_shell_ls_globals *globals, DISPLAY *) |
void | printlong (rtems_shell_ls_globals *globals, DISPLAY *) |
void | printscol (rtems_shell_ls_globals *globals, DISPLAY *) |
void | printstream (rtems_shell_ls_globals *globals, DISPLAY *) |
int | safe_print (rtems_shell_ls_globals *globals, const char *) |
void | usage (rtems_shell_ls_globals *globals) |
void | strmode (mode_t mode, char *p) |
