libpci
pci
cfg_read.h
1
/* PCI Read Configuration Library. Read current config that bootloader/BIOS
2
* has setup.
3
4
* COPYRIGHT (c) 2010 Cobham Gaisler AB.
5
6
* The license and distribution terms for this file may be
7
* found in the file LICENSE in this distribution or at
8
* http://www.rtems.org/license/LICENSE.
9
10
11
12
#ifndef __PCI_CFG_READ_H__
13
#define __PCI_CFG_READ_H__
14
15
/* Build PCI device tree in "struct pci_bus pci_hb" according to current setup
16
* in hardware. Devices/buses are created by reading the resource assignments
17
* that the BIOS/bootloader has already setup for us.
18
19
extern
int
pci_config_read(
void
20
21
#endif
