libdl
include
arch
arm
machine
elf_machdep.h
1
/* $NetBSD: elf_machdep.h,v 1.8 2009/05/30 05:56:52 skrll Exp $ */
2
3
#if defined(__ARMEB__)
4
#define ELF32_MACHDEP_ENDIANNESS ELFDATA2MSB
5
#else
6
#define ELF32_MACHDEP_ENDIANNESS ELFDATA2LSB
7
#endif
8
9
#define ELF64_MACHDEP_ENDIANNESS XXX
/* break compilation */
10
#define ELF64_MACHDEP_ID_CASES \
11
/* no 64-bit ELF machine types supported */
12
13
/* Processor specific flags for the ELF header e_flags field. */
14
#define EF_ARM_RELEXEC 0x00000001
15
#define EF_ARM_HASENTRY 0x00000002
16
#define EF_ARM_INTERWORK 0x00000004
/* GNU binutils 000413 */
17
#define EF_ARM_SYMSARESORTED 0x00000004
/* ARM ELF A08 */
18
#define EF_ARM_APCS_26 0x00000008
19
#define EF_ARM_DYNSYMSUSESEGIDX 0x00000008
/* ARM ELF B01 */
20
#define EF_ARM_APCS_FLOAT 0x00000010
21
#define EF_ARM_MAPSYMSFIRST 0x00000010
/* ARM ELF B01 */
22
#define EF_ARM_PIC 0x00000020
23
#define EF_ARM_ALIGN8 0x00000040
/* 8-bit structure alignment. */
24
#define EF_ARM_NEW_ABI 0x00000080
25
#define EF_ARM_OLD_ABI 0x00000100
26
#define EF_ARM_SOFT_FLOAT 0x00000200
27
#define EF_ARM_EABIMASK 0xff000000
28
29
#define ELF32_MACHDEP_ID_CASES \
30
case EM_ARM: \
31
break;
32
33
#define ELF32_MACHDEP_ID EM_ARM
34
35
#define ARCH_ELFSIZE 32
/* MD native binary size */
36
37
/* Processor specific relocation types */
38
39
#define R_ARM_NONE 0
40
#define R_ARM_PC24 1
41
#define R_ARM_ABS32 2
42
#define R_ARM_REL32 3
43
#define R_ARM_PC13 4
44
#define R_ARM_ABS16 5
45
#define R_ARM_ABS12 6
46
#define R_ARM_THM_ABS5 7
47
#define R_ARM_ABS8 8
48
#define R_ARM_SBREL32 9
49
#define R_ARM_THM_CALL 10
50
#define R_ARM_THM_PC8 11
51
#define R_ARM_AMP_VCALL9 12
52
#define R_ARM_SWI24 13
53
#define R_ARM_THM_SWI8 14
54
#define R_ARM_XPC25 15
55
#define R_ARM_THM_XPC22 16
56
57
/* TLS relocations */
58
#define R_ARM_TLS_DTPMOD32 17
/* ID of module containing symbol */
59
#define R_ARM_TLS_DTPOFF32 18
/* Offset in TLS block */
60
#define R_ARM_TLS_TPOFF32 19
/* Offset in static TLS block */
61
62
/* 20-31 are reserved for ARM Linux. */
63
#define R_ARM_COPY 20
64
#define R_ARM_GLOB_DAT 21
65
#define R_ARM_JUMP_SLOT 22
66
#define R_ARM_RELATIVE 23
67
#define R_ARM_GOTOFF 24
68
#define R_ARM_GOTPC 25
69
#define R_ARM_GOT32 26
70
#define R_ARM_PLT32 27
71
#define R_ARM_CALL 28
72
#define R_ARM_JUMP24 29
73
#define R_ARM_THM_JUMP24 30
74
#define R_ARM_BASE_ABS 31
75
76
#define R_ARM_ALU_PCREL_7_0 32
77
#define R_ARM_ALU_PCREL_15_8 33
78
#define R_ARM_ALU_PCREL_23_15 34
79
#define R_ARM_ALU_SBREL_11_0 35
80
#define R_ARM_ALU_SBREL_19_12 36
81
#define R_ARM_ALU_SBREL_27_20 37
82
#define R_ARM_V4BX 40
83
#define R_ARM_TARGET2 41
84
#define R_ARM_PREL31 42
85
86
#define R_ARM_MOVW_ABS_NC 43
87
#define R_ARM_MOVT_ABS 44
88
89
#define R_ARM_THM_MOVW_ABS_NC 47
90
#define R_ARM_THM_MOVT_ABS 48
91
92
#define R_ARM_THM_JUMP19 51
93
94
/* 96-111 are reserved to G++. */
95
#define R_ARM_GNU_VTENTRY 100
96
#define R_ARM_GNU_VTINHERIT 101
97
#define R_ARM_THM_JUMP11 102
98
#define R_ARM_THM_JUMP8 103
99
100
/* More TLS relocations */
101
#define R_ARM_TLS_GD32 104
/* PC-rel 32 bit for global dynamic */
102
#define R_ARM_TLS_LDM32 105
/* PC-rel 32 bit for local dynamic */
103
#define R_ARM_TLS_LDO32 106
/* 32 bit offset relative to TLS */
104
#define R_ARM_TLS_IE32 107
/* PC-rel 32 bit for GOT entry of */
105
#define R_ARM_TLS_LE32 108
106
#define R_ARM_TLS_LDO12 109
107
#define R_ARM_TLS_LE12 110
108
#define R_ARM_TLS_IE12GP 111
109
110
/* 112-127 are reserved for private experiments. */
111
112
#define R_ARM_RXPC25 249
113
#define R_ARM_RSBREL32 250
114
#define R_ARM_THM_RPC22 251
115
#define R_ARM_RREL32 252
116
#define R_ARM_RABS32 253
117
#define R_ARM_RPC24 254
118
#define R_ARM_RBASE 255
119
120
#define R_TYPE(name) __CONCAT(R_ARM_,name)
121
122
/* Processor specific program header flags */
123
#define PF_ARM_SB 0x10000000
124
#define PF_ARM_PI 0x20000000
125
#define PF_ARM_ENTRY 0x80000000
126
127
/* Processor specific section header flags */
128
#define SHF_ENTRYSECT 0x10000000
129
#define SHF_COMDEF 0x80000000
130
131
/* Processor specific symbol types */
132
#define STT_ARM_TFUNC STT_LOPROC
