watchdogimpl.h File Reference
Inlined Routines in the Watchdog Handler. More...
#include <rtems/score/isrlock.h>
Include dependency graph for watchdogimpl.h:
struct  Watchdog_Iterator
 Iterator item to synchronize concurrent insert, remove and tickle operations. More...
struct  Watchdog_Header
 Watchdog header. More...
#define WATCHDOG_INITIALIZER(routine, id, user_data)
 Watchdog initializer for static initialization. More...
RTEMS_INLINE_ROUTINE void _Watchdog_Acquire (Watchdog_Header *header, ISR_lock_Context *lock_context)
RTEMS_INLINE_ROUTINE void _Watchdog_Release (Watchdog_Header *header, ISR_lock_Context *lock_context)
RTEMS_INLINE_ROUTINE void _Watchdog_Flash (Watchdog_Header *header, ISR_lock_Context *lock_context)
void _Watchdog_Handler_initialization (void)
 Initialize the watchdog handler. More...
void _Watchdog_Tick (void)
 Triggers a watchdog tick. More...
Watchdog_States _Watchdog_Remove (Watchdog_Header *header, Watchdog_Control *the_watchdog)
 Removes the_watchdog from the watchdog chain. More...
void _Watchdog_Adjust_backward (Watchdog_Header *header, Watchdog_Interval units)
 Adjusts the header watchdog chain in the backward direction for units ticks. More...
void _Watchdog_Adjust_backward_locked (Watchdog_Header *header, Watchdog_Interval units)
 Adjusts the watchdogs in backward direction in a locked context. More...
void _Watchdog_Adjust_forward (Watchdog_Header *header, Watchdog_Interval units)
 Adjusts the header watchdog chain in the forward direction for units ticks. More...
void _Watchdog_Adjust_forward_locked (Watchdog_Header *header, Watchdog_Interval units, ISR_lock_Context *lock_context)
 Adjusts the watchdogs in forward direction in a locked context. More...
void _Watchdog_Insert (Watchdog_Header *header, Watchdog_Control *the_watchdog)
 Inserts the_watchdog into the header watchdog chain for a time of units. More...
void _Watchdog_Insert_locked (Watchdog_Header *header, Watchdog_Control *the_watchdog, ISR_lock_Context *lock_context)
 Inserts the watchdog in a locked context. More...
void _Watchdog_Tickle (Watchdog_Header *header)
 This routine is invoked at appropriate intervals to update the header watchdog chain. More...
RTEMS_INLINE_ROUTINE void _Watchdog_Preinitialize (Watchdog_Control *the_watchdog)
 Pre-initializes a watchdog. More...
RTEMS_INLINE_ROUTINE void _Watchdog_Initialize (Watchdog_Control *the_watchdog, Watchdog_Service_routine_entry routine, Objects_Id id, void *user_data)
 This routine initializes the specified watchdog. More...
RTEMS_INLINE_ROUTINE bool _Watchdog_Is_active (Watchdog_Control *the_watchdog)
 This routine returns true if the watchdog timer is in the ACTIVE state, and false otherwise.
RTEMS_INLINE_ROUTINE void _Watchdog_Activate (Watchdog_Control *the_watchdog)
 This routine activates THE_WATCHDOG timer which is already on a watchdog chain.
RTEMS_INLINE_ROUTINE void _Watchdog_Tickle_ticks (void)
 This routine is invoked at each clock tick to update the ticks watchdog chain.
RTEMS_INLINE_ROUTINE void _Watchdog_Tickle_seconds (void)
 This routine is invoked at each clock tick to update the seconds watchdog chain.
RTEMS_INLINE_ROUTINE void _Watchdog_Insert_ticks (Watchdog_Control *the_watchdog, Watchdog_Interval units)
 This routine inserts THE_WATCHDOG into the ticks watchdog chain for a time of UNITS ticks. More...
RTEMS_INLINE_ROUTINE void _Watchdog_Insert_seconds (Watchdog_Control *the_watchdog, Watchdog_Interval units)
 This routine inserts THE_WATCHDOG into the seconds watchdog chain for a time of UNITS seconds. More...
RTEMS_INLINE_ROUTINE Watchdog_States _Watchdog_Remove_ticks (Watchdog_Control *the_watchdog)
RTEMS_INLINE_ROUTINE Watchdog_States _Watchdog_Remove_seconds (Watchdog_Control *the_watchdog)
RTEMS_INLINE_ROUTINE void _Watchdog_Reset_ticks (Watchdog_Control *the_watchdog)
 This routine resets THE_WATCHDOG timer to its state at INSERT time. More...
RTEMS_INLINE_ROUTINE Watchdog_Control * _Watchdog_Next (Watchdog_Control *the_watchdog)
 This routine returns a pointer to the watchdog timer following THE_WATCHDOG on the watchdog chain.
RTEMS_INLINE_ROUTINE Watchdog_Control * _Watchdog_Previous (Watchdog_Control *the_watchdog)
 This routine returns a pointer to the watchdog timer preceding THE_WATCHDOG on the watchdog chain.
RTEMS_INLINE_ROUTINE Watchdog_Control * _Watchdog_First (Watchdog_Header *header)
 This routine returns a pointer to the first watchdog timer on the watchdog chain HEADER.
RTEMS_INLINE_ROUTINE Watchdog_Control * _Watchdog_Last (Watchdog_Header *header)
 This routine returns a pointer to the last watchdog timer on the watchdog chain HEADER.
RTEMS_INLINE_ROUTINE bool _Watchdog_Is_empty (const Watchdog_Header *header)
RTEMS_INLINE_ROUTINE void _Watchdog_Header_initialize (Watchdog_Header *header)
SCORE_EXTERN Watchdog_Header _Watchdog_Ticks_header
 Watchdog chain which is managed at ticks. More...
SCORE_EXTERN Watchdog_Header _Watchdog_Seconds_header
 Watchdog chain which is managed at second boundaries. More...
This file contains the static inline implementation of all inlined routines in the Watchdog Handler.
