#define | ELF32_MACHDEP_ENDIANNESS ELFDATA2LSB |
| #define | ELF32_MACHDEP_ID_CASES |
#define | ELF32_MACHDEP_ID EM_V850 |
#define | EF_V850_ARCH 0xf0000000 |
#define | E_V850_ARCH 0x00000000 |
#define | E_V850E_ARCH 0x10000000 |
#define | E_V850E1_ARCH 0x20000000 |
#define | E_V850E2_ARCH 0x30000000 |
#define | E_V850E2V3_ARCH 0x40000000 |
#define | ARCH_ELFSIZE 32 |
#define | R_V850_NONE 0 |
#define | R_V850_9_PCREL 1 |
#define | R_V850_22_PCREL 2 |
#define | R_V850_HI16_S 3 |
#define | R_V850_HI16 4 |
#define | R_V850_LO16 5 |
#define | R_V850_ABS32 6 |
#define | R_V850_16 7 |
#define | R_V850_8 8 |
#define | R_V850_SDA_16_16_OFFSET 9 |
#define | R_V850_SDA_15_16_OFFSET 10 |
#define | R_V850_ZDA_16_16_OFFSET 11 |
#define | R_V850_ZDA_15_16_OFFSET 12 |
#define | R_V850_TDA_6_8_OFFSET 13 |
#define | R_V850_TDA_7_8_OFFSET 14 |
#define | R_V850_TDA_7_7_OFFSET 15 |
#define | R_V850_TDA_16_16_OFFSET 16 |
#define | R_V850_TDA_4_5_OFFSET 17 |
#define | R_V850_TDA_4_4_OFFSET 18 |
#define | R_V850_SDA_16_16_SPLIT_OFFSET 19 |
#define | R_V850_ZDA_16_16_SPLIT_OFFSET 20 |
#define | R_V850_CALLT_6_7_OFFSET 21 |
#define | R_V850_CALLT_16_16_OFFSET 22 |
#define | R_V850_GNU_VTINHERIT 23 |
#define | R_V850_GNU_VTENTRY 24 |
#define | R_V850_LONGCALL 25 |
#define | R_V850_LONGJUMP 26 |
#define | R_V850_ALIGN 27 |
#define | R_V850_REL32 28 |
#define | R_V850_LO16_SPLIT_OFFSET 29 |
#define | R_V850_16_PCREL 30 |
#define | R_V850_17_PCREL 31 |
#define | R_V850_23 32 |
#define | R_V850_32_PCREL 33 |
#define | R_V850_32_ABS 34 |
#define | R_V850_16_SPLIT_OFFSET 35 |
#define | R_V850_16_S1 36 |
#define | R_V850_LO16_S1 37 |
#define | R_V850_CALLT_15_16_OFFSET 38 |
#define | R_V850_32_GOTPCREL 39 |
#define | R_V850_16_GOT 40 |
#define | R_V850_32_GOT 41 |
#define | R_V850_22_PLT 42 |
#define | R_V850_32_PLT 43 |
#define | R_V850_COPY 44 |
#define | R_V850_GLOB_DAT 45 |
#define | R_V850_JMP_SLOT 46 |
#define | R_V850_RELATIVE 47 |
#define | R_V850_16_GOTOFF 48 |
#define | R_V850_32_GOTOFF 49 |
#define | R_V850_CODE 50 |
#define | R_V850_DATA 51 |
#define | R_TYPE(name) __CONCAT(R_V850_,name) |
◆ ELF32_MACHDEP_ID_CASES
| #define ELF32_MACHDEP_ID_CASES |
