#define | _PATH_LOG "/var/run/log" |
#define | _PATH_OLDLOG "/dev/log" /* backward compatibility */ |
#define | LOG_EMERG 0 /* system is unusable */ |
#define | LOG_ALERT 1 /* action must be taken immediately */ |
#define | LOG_CRIT 2 /* critical conditions */ |
#define | LOG_ERR 3 /* error conditions */ |
#define | LOG_WARNING 4 /* warning conditions */ |
#define | LOG_NOTICE 5 /* normal but significant condition */ |
#define | LOG_INFO 6 /* informational */ |
#define | LOG_DEBUG 7 /* debug-level messages */ |
#define | LOG_PRIMASK 0x07 /* mask to extract priority part (internal) */ |
#define | LOG_PRI(p) ((p) & LOG_PRIMASK) |
#define | LOG_MAKEPRI(fac, pri) ((fac) | (pri)) |
#define | LOG_KERN (0<<3) /* kernel messages */ |
#define | LOG_USER (1<<3) /* random user-level messages */ |
#define | LOG_MAIL (2<<3) /* mail system */ |
#define | LOG_DAEMON (3<<3) /* system daemons */ |
#define | LOG_AUTH (4<<3) /* authorization messages */ |
#define | LOG_SYSLOG (5<<3) /* messages generated internally by syslogd */ |
#define | LOG_LPR (6<<3) /* line printer subsystem */ |
#define | LOG_NEWS (7<<3) /* network news subsystem */ |
#define | LOG_UUCP (8<<3) /* UUCP subsystem */ |
#define | LOG_CRON (9<<3) /* clock daemon */ |
#define | LOG_AUTHPRIV (10<<3) /* authorization messages (private) */ |
#define | LOG_FTP (11<<3) /* ftp daemon */ |
#define | LOG_NTP (12<<3) /* NTP subsystem */ |
#define | LOG_LOCAL0 (16<<3) /* reserved for local use */ |
#define | LOG_LOCAL1 (17<<3) /* reserved for local use */ |
#define | LOG_LOCAL2 (18<<3) /* reserved for local use */ |
#define | LOG_LOCAL3 (19<<3) /* reserved for local use */ |
#define | LOG_LOCAL4 (20<<3) /* reserved for local use */ |
#define | LOG_LOCAL5 (21<<3) /* reserved for local use */ |
#define | LOG_LOCAL6 (22<<3) /* reserved for local use */ |
#define | LOG_LOCAL7 (23<<3) /* reserved for local use */ |
#define | LOG_NFACILITIES 24 /* current number of facilities */ |
#define | LOG_FACMASK 0x03f8 /* mask to extract facility part */ |
#define | LOG_FAC(p) (((p) & LOG_FACMASK) >> 3) |
#define | LOG_MASK(pri) (1 << (pri)) /* mask for one priority */ |
#define | LOG_UPTO(pri) ((1 << ((pri)+1)) - 1) /* all priorities through pri */ |
#define | LOG_PID 0x01 /* log the pid with each message */ |
#define | LOG_CONS 0x02 /* log on the console if errors in sending */ |
#define | LOG_ODELAY 0x04 /* delay open until first syslog() (default) */ |
#define | LOG_NDELAY 0x08 /* don't delay open */ |
#define | LOG_NOWAIT 0x10 /* don't wait for console forks: DEPRECATED */ |
#define | LOG_PERROR 0x20 /* log to stderr as well */ |
