sparc/machine/elf_machdep.h File Reference
#define ELF32_MACHDEP_ENDIANNESS   ELFDATA2MSB
#define ELF32_MACHDEP_ID_CASES
#define ELF64_MACHDEP_ENDIANNESS   ELFDATA2MSB
#define ELF64_MACHDEP_ID_CASES
#define ELF32_MACHDEP_ID   EM_SPARC /* XXX right? */
#define ARCH_ELFSIZE   32 /* MD native binary size */
#define R_SPARC_NONE   0
#define R_SPARC_8   1
#define R_SPARC_16   2
#define R_SPARC_32   3
#define R_SPARC_DISP8   4
#define R_SPARC_DISP16   5
#define R_SPARC_DISP32   6
#define R_SPARC_WDISP30   7
#define R_SPARC_WDISP22   8
#define R_SPARC_HI22   9
#define R_SPARC_22   10
#define R_SPARC_13   11
#define R_SPARC_LO10   12
#define R_SPARC_GOT10   13
#define R_SPARC_GOT13   14
#define R_SPARC_GOT22   15
#define R_SPARC_PC10   16
#define R_SPARC_PC22   17
#define R_SPARC_WPLT30   18
#define R_SPARC_COPY   19
#define R_SPARC_GLOB_DAT   20
#define R_SPARC_JMP_SLOT   21
#define R_SPARC_RELATIVE   22
#define R_SPARC_UA32   23
#define R_SPARC_PLT32   24
#define R_SPARC_HIPLT22   25
#define R_SPARC_LOPLT10   26
#define R_SPARC_PCPLT32   27
#define R_SPARC_PCPLT22   28
#define R_SPARC_PCPLT10   29
#define R_SPARC_10   30
#define R_SPARC_11   31
#define R_SPARC_64   32
#define R_SPARC_OLO10   33
#define R_SPARC_HH22   34
#define R_SPARC_HM10   35
#define R_SPARC_LM22   36
#define R_SPARC_PC_HH22   37
#define R_SPARC_PC_HM10   38
#define R_SPARC_PC_LM22   39
#define R_SPARC_WDISP16   40
#define R_SPARC_WDISP19   41
#define R_SPARC_GLOB_JMP   42
#define R_SPARC_7   43
#define R_SPARC_5   44
#define R_SPARC_6   45
#define R_SPARC_TLS_GD_HI22   56
#define R_SPARC_TLS_GD_LO10   57
#define R_SPARC_TLS_GD_ADD   58
#define R_SPARC_TLS_GD_CALL   59
#define R_SPARC_TLS_LDM_HI22   60
#define R_SPARC_TLS_LDM_LO10   61
#define R_SPARC_TLS_LDM_ADD   62
#define R_SPARC_TLS_LDM_CALL   63
#define R_SPARC_TLS_LDO_HIX22   64
#define R_SPARC_TLS_LDO_LOX10   65
#define R_SPARC_TLS_LDO_ADD   66
#define R_SPARC_TLS_IE_HI22   67
#define R_SPARC_TLS_IE_LO10   68
#define R_SPARC_TLS_IE_LD   69
#define R_SPARC_TLS_IE_LDX   70
#define R_SPARC_TLS_IE_ADD   71
#define R_SPARC_TLS_LE_HIX22   72
#define R_SPARC_TLS_LE_LOX10   73
#define R_SPARC_TLS_DTPMOD32   74
#define R_SPARC_TLS_DTPMOD64   75
#define R_SPARC_TLS_DTPOFF32   76
#define R_SPARC_TLS_DTPOFF64   77
#define R_SPARC_TLS_TPOFF32   78
#define R_SPARC_TLS_TPOFF64   79
#define R_TYPE(name)   __CONCAT(R_SPARC_,name)
◆ ELF32_MACHDEP_ID_CASES
Value:
case EM_SPARC: \
case EM_SPARC32PLUS: \
break;
◆ ELF64_MACHDEP_ID_CASES
Value:
case EM_SPARCV9: \
/* no 64-bit ELF machine types supported */
