Macros | Typedefs | Functions
sapi/include/rtems/chain.h File Reference
Chain API. More...
#include <rtems/rtems/event.h>
Include dependency graph for sapi/include/rtems/chain.h:
#define RTEMS_CHAIN_INITIALIZER_EMPTY(name)   CHAIN_INITIALIZER_EMPTY( name )
 Chain initializer for an empty chain with designator name.
#define RTEMS_CHAIN_INITIALIZER_ONE_NODE(node)   CHAIN_INITIALIZER_ONE_NODE( node )
 Chain initializer for a chain with one node. More...
#define RTEMS_CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN(chain)   CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN( chain )
 Chain node initializer for a chain containing exactly this node. More...
#define RTEMS_CHAIN_DEFINE_EMPTY(name)   rtems_chain_control name = RTEMS_CHAIN_INITIALIZER_EMPTY( name )
 Chain definition for an empty chain with designator name.
typedef Chain_Node rtems_chain_node
typedef Chain_Control rtems_chain_control
rtems_status_code rtems_chain_append_with_notification (rtems_chain_control *chain, rtems_chain_node *node, rtems_id task, rtems_event_set events)
 Appends the node to the chain and sends the events to the task if the chain was empty before the append. More...
rtems_status_code rtems_chain_prepend_with_notification (rtems_chain_control *chain, rtems_chain_node *node, rtems_id task, rtems_event_set events)
 Prepends the node to the chain and sends the events to the task if the chain was empty before the prepend. More...
rtems_status_code rtems_chain_get_with_notification (rtems_chain_control *chain, rtems_id task, rtems_event_set events, rtems_chain_node **node)
 Gets the first node of the chain and sends the events to the task if the chain is empty after the get. More...
rtems_status_code rtems_chain_get_with_wait (rtems_chain_control *chain, rtems_event_set events, rtems_interval timeout, rtems_chain_node **node)
 Gets the first node of the chain and sends the events to the task if the chain is empty afterwards. More...
RTEMS_INLINE_ROUTINE void rtems_chain_initialize (rtems_chain_control *the_chain, void *starting_address, size_t number_nodes, size_t node_size)
 Initialize a chain Header. More...
RTEMS_INLINE_ROUTINE void rtems_chain_initialize_empty (rtems_chain_control *the_chain)
 Initialize this chain as empty. More...
RTEMS_INLINE_ROUTINE void rtems_chain_set_off_chain (rtems_chain_node *node)
 Set off chain. More...
RTEMS_INLINE_ROUTINE bool rtems_chain_is_node_off_chain (const rtems_chain_node *node)
 Is the node off chain. More...
RTEMS_INLINE_ROUTINE bool rtems_chain_is_null_node (const rtems_chain_node *the_node)
 Is the chain node pointer NULL. More...
RTEMS_INLINE_ROUTINE rtems_chain_node * rtems_chain_head (rtems_chain_control *the_chain)
 Return pointer to Chain Head. More...
RTEMS_INLINE_ROUTINE const rtems_chain_node * rtems_chain_immutable_head (const rtems_chain_control *the_chain)
 Return pointer to immutable Chain Head. More...
RTEMS_INLINE_ROUTINE rtems_chain_node * rtems_chain_tail (rtems_chain_control *the_chain)
 Return pointer to Chain Tail. More...
RTEMS_INLINE_ROUTINE const rtems_chain_node * rtems_chain_immutable_tail (const rtems_chain_control *the_chain)
 Return pointer to immutable Chain Tail. More...
RTEMS_INLINE_ROUTINE rtems_chain_node * rtems_chain_first (rtems_chain_control *the_chain)
 Return pointer to Chain's First node after the permanent head. More...
RTEMS_INLINE_ROUTINE const rtems_chain_node * rtems_chain_immutable_first (const rtems_chain_control *the_chain)
 Return pointer to immutable Chain's First node. More...
RTEMS_INLINE_ROUTINE rtems_chain_node * rtems_chain_last (rtems_chain_control *the_chain)
 Return pointer to Chain's Last node before the permanent tail. More...
RTEMS_INLINE_ROUTINE const rtems_chain_node * rtems_chain_immutable_last (const rtems_chain_control *the_chain)
 Return pointer to immutable Chain's Last node. More...
RTEMS_INLINE_ROUTINE rtems_chain_node * rtems_chain_next (rtems_chain_node *the_node)
 Return pointer the next node from this node. More...
RTEMS_INLINE_ROUTINE const rtems_chain_node * rtems_chain_immutable_next (const rtems_chain_node *the_node)
 Return pointer the immutable next node from this node. More...
RTEMS_INLINE_ROUTINE rtems_chain_node * rtems_chain_previous (rtems_chain_node *the_node)
 Return pointer the previous node from this node. More...
RTEMS_INLINE_ROUTINE const rtems_chain_node * rtems_chain_immutable_previous (const rtems_chain_node *the_node)
 Return pointer the immutable previous node from this node. More...
RTEMS_INLINE_ROUTINE bool rtems_chain_are_nodes_equal (const rtems_chain_node *left, const rtems_chain_node *right)
 Are Two nodes equal. More...
RTEMS_INLINE_ROUTINE bool rtems_chain_is_empty (const rtems_chain_control *the_chain)
 Is the chain empty. More...
RTEMS_INLINE_ROUTINE bool rtems_chain_is_first (const rtems_chain_node *the_node)
 Is this the first node on the chain. More...
RTEMS_INLINE_ROUTINE bool rtems_chain_is_last (const rtems_chain_node *the_node)
 Is this the last node on the chain. More...
RTEMS_INLINE_ROUTINE bool rtems_chain_has_only_one_node (const rtems_chain_control *the_chain)
 Does this chain have only one node. More...
RTEMS_INLINE_ROUTINE bool rtems_chain_is_head (const rtems_chain_control *the_chain, const rtems_chain_node *the_node)
 Is this node the chain head. More...
RTEMS_INLINE_ROUTINE bool rtems_chain_is_tail (const rtems_chain_control *the_chain, const rtems_chain_node *the_node)
 Is this node the chain tail. More...
RTEMS_INLINE_ROUTINE void rtems_chain_extract (rtems_chain_node *the_node)
 Extract the specified node from a chain. More...
RTEMS_INLINE_ROUTINE void rtems_chain_extract_unprotected (rtems_chain_node *the_node)
 Extract the specified node from a chain (unprotected). More...
RTEMS_INLINE_ROUTINE rtems_chain_node * rtems_chain_get (rtems_chain_control *the_chain)
 Obtain the first node on a chain. More...
RTEMS_INLINE_ROUTINE rtems_chain_node * rtems_chain_get_unprotected (rtems_chain_control *the_chain)
 See _Chain_Get_unprotected().
RTEMS_INLINE_ROUTINE void rtems_chain_insert (rtems_chain_node *after_node, rtems_chain_node *the_node)
 Insert a node on a chain. More...
RTEMS_INLINE_ROUTINE void rtems_chain_insert_unprotected (rtems_chain_node *after_node, rtems_chain_node *the_node)
 See _Chain_Insert_unprotected().
RTEMS_INLINE_ROUTINE void rtems_chain_append (rtems_chain_control *the_chain, rtems_chain_node *the_node)
 Append a node on the end of a chain. More...
RTEMS_INLINE_ROUTINE void rtems_chain_append_unprotected (rtems_chain_control *the_chain, rtems_chain_node *the_node)
 Append a node on the end of a chain (unprotected). More...
RTEMS_INLINE_ROUTINE void rtems_chain_prepend (rtems_chain_control *the_chain, rtems_chain_node *the_node)
 Prepend a node. More...
RTEMS_INLINE_ROUTINE void rtems_chain_prepend_unprotected (rtems_chain_control *the_chain, rtems_chain_node *the_node)
 Prepend a node (unprotected). More...
RTEMS_INLINE_ROUTINE bool rtems_chain_append_with_empty_check (rtems_chain_control *chain, rtems_chain_node *node)
 Checks if the chain is empty and appends the node. More...
RTEMS_INLINE_ROUTINE bool rtems_chain_prepend_with_empty_check (rtems_chain_control *chain, rtems_chain_node *node)
 Checks if the chain is empty and prepends the node. More...
RTEMS_INLINE_ROUTINE bool rtems_chain_get_with_empty_check (rtems_chain_control *chain, rtems_chain_node **node)
 Tries to get the first node and check if the chain is empty afterwards. More...
RTEMS_INLINE_ROUTINE size_t rtems_chain_node_count_unprotected (const rtems_chain_control *chain)
 Returns the node count of the chain. More...
Chain API.
