Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
resolv.h File Reference
#include <sys/param.h>
#include <sys/types.h>
#include <sys/cdefs.h>
#include <netinet/in.h>
Include dependency graph for resolv.h:
struct  res_sym
struct  __res_state
#define __RES   19960801
#define _PATH_RESCONF   "/etc/resolv.conf"
#define MAXNS   3 /*%< max # name servers we'll track */
#define MAXDFLSRCH   3 /*%< # default domain levels to try */
#define MAXDNSRCH   6 /*%< max # domains in search path */
#define LOCALDOMAINPARTS   2 /*%< min levels in name that is "local" */
#define RES_TIMEOUT   5 /*%< min. seconds between retries */
#define MAXRESOLVSORT   10 /*%< number of net to sort on */
#define RES_MAXNDOTS   15 /*%< should reflect bit field size */
#define nsaddr   nsaddr_list[0] /*%< for backward compatibility */
#define RES_INIT   0x00000001 /*%< address initialized */
#define RES_DEBUG   0x00000002 /*%< print debug messages */
#define RES_AAONLY   0x00000004 /*%< authoritative answers only (!IMPL)*/
#define RES_USEVC   0x00000008 /*%< use virtual circuit */
#define RES_PRIMARY   0x00000010 /*%< query primary server only (!IMPL) */
#define RES_IGNTC   0x00000020 /*%< ignore truncation errors */
#define RES_RECURSE   0x00000040 /*%< recursion desired */
#define RES_DEFNAMES   0x00000080 /*%< use default domain name */
#define RES_STAYOPEN   0x00000100 /*%< Keep TCP socket open */
#define RES_DNSRCH   0x00000200 /*%< search up local domain tree */
#define RES_INSECURE1   0x00000400 /*%< type 1 security disabled */
#define RES_INSECURE2   0x00000800 /*%< type 2 security disabled */
#define RES_NOALIASES   0x00001000 /*%< shuts off HOSTALIASES feature */
#define RES_USE_INET6   0x00002000 /*%< use/map IPv6 in gethostbyname() */
#define RES_NOTLDQUERY   0x00004000 /*%< Don't query TLD names */
#define RES_DEFAULT
#define RES_PRF_STATS   0x00000001
#define RES_PRF_UPDATE   0x00000002
#define RES_PRF_CLASS   0x00000004
#define RES_PRF_CMD   0x00000008
#define RES_PRF_QUES   0x00000010
#define RES_PRF_ANS   0x00000020
#define RES_PRF_AUTH   0x00000040
#define RES_PRF_ADD   0x00000080
#define RES_PRF_HEAD1   0x00000100
#define RES_PRF_HEAD2   0x00000200
#define RES_PRF_TTLID   0x00000400
#define RES_PRF_HEADX   0x00000800
#define RES_PRF_QUERY   0x00001000
#define RES_PRF_REPLY   0x00002000
#define RES_PRF_INIT   0x00004000
#define fp_nquery   __fp_nquery
#define fp_query   __fp_query
#define hostalias   __hostalias
#define p_query   __p_query
#define res_close   __res_close
#define res_init   __res_init
#define res_isourserver   __res_isourserver
#define res_mkquery   __res_mkquery
#define res_query   __res_query
#define res_querydomain   __res_querydomain
#define res_search   __res_search
#define res_send   __res_send
#define b64_ntop   __b64_ntop
#define b64_pton   __b64_pton
#define dn_comp   __dn_comp
#define dn_count_labels   __dn_count_labels
#define dn_expand   __dn_expand
#define dn_skipname   __dn_skipname
#define fp_resstat   __fp_resstat
#define loc_aton   __loc_aton
#define loc_ntoa   __loc_ntoa
#define p_cdname   __p_cdname
#define p_cdnname   __p_cdnname
#define p_class   __p_class
#define p_fqname   __p_fqname
#define p_fqnname   __p_fqnname
#define p_option   __p_option
#define p_secstodate   __p_secstodate
#define p_section   __p_section
#define p_time   __p_time
#define p_type   __p_type
#define putlong   __putlong
#define putshort   __putshort
#define res_dnok   __res_dnok
#define res_hnok   __res_hnok
#define res_mailok   __res_mailok
#define res_nameinquery   __res_nameinquery
#define res_ownok   __res_ownok
#define res_queriesmatch   __res_queriesmatch
#define res_randomid   __res_randomid
#define sym_ntop   __sym_ntop
#define sym_ntos   __sym_ntos
#define sym_ston   __sym_ston
#define res_send_setqhook   __res_send_setqhook
#define res_send_setrhook   __res_send_setrhook
#define res_mkupdate   __res_mkupdate
#define res_mkupdrec   __res_mkupdrec
#define res_freeupdrec   __res_freeupdrec
typedef res_sendhookact(* res_send_qhook) (struct sockaddr_in *const *ns, const u_char **query, int *querylen, u_char *ans, int anssiz, int *resplen)
typedef res_sendhookact(* res_send_rhook) (const struct sockaddr_in *ns, const u_char *query, int querylen, u_char *ans, int anssiz, int *resplen)
typedef struct __res_state * res_state
enum  res_sendhookact {
  res_goahead, res_nextns, res_modified, res_done,
  res_error
__BEGIN_DECLS void fp_nquery (const u_char *, int, FILE *)
void fp_query (const u_char *, FILE *)
const char * hostalias (const char *)
void p_query (const u_char *)
void res_close (void)
int res_init (void)
int res_isourserver (const struct sockaddr_in *)
int res_mkquery (int, const char *, int, int, const u_char *, int, const u_char *, u_char *, int)
int res_query (const char *, int, int, u_char *, int)
int res_querydomain (const char *, const char *, int, int, u_char *, int)
int res_search (const char *, int, int, u_char *, int)
int res_send (const u_char *, int, u_char *, int)
__BEGIN_DECLS int res_hnok (const char *)
int res_ownok (const char *)
int res_mailok (const char *)
int res_dnok (const char *)
int sym_ston (const struct res_sym *, const char *, int *)
const char * sym_ntos (const struct res_sym *, int, int *)
const char * sym_ntop (const struct res_sym *, int, int *)
int b64_ntop (u_char const *, size_t, char *, size_t)
int b64_pton (char const *, u_char *, size_t)
int loc_aton (const char *, u_char *)
const char * loc_ntoa (const u_char *, char *)
int dn_skipname (const u_char *, const u_char *)
void fp_resstat (struct __res_state *, FILE *)
void putlong (u_int32_t, u_char *)
void putshort (u_int16_t, u_char *)
const char * p_class (int)
const char * p_time (u_int32_t)
const char * p_type (int)
const u_char * p_cdnname (const u_char *, const u_char *, int, FILE *)
const u_char * p_cdname (const u_char *, const u_char *, FILE *)
const u_char * p_fqnname (const u_char *, const u_char *, int, char *, int)
const u_char * p_fqname (const u_char *, const u_char *, FILE *)
const char * p_option (u_long)
char * p_secstodate (u_long)
int dn_count_labels (const char *)
int dn_comp (const char *, u_char *, int, u_char **, u_char **)
int dn_expand (const u_char *, const u_char *, const u_char *, char *, int)
u_int res_randomid (void)
int res_nameinquery (const char *, int, int, const u_char *, const u_char *)
int res_queriesmatch (const u_char *, const u_char *, const u_char *, const u_char *)
const char * p_section (int, int)
void res_send_setqhook (res_send_qhook)
void res_send_setrhook (res_send_rhook)
int h_errno
__END_DECLS struct __res_state _res
const struct res_sym __p_class_syms []
const struct res_sym __p_type_syms []
◆ RES_DEFAULT
#define RES_DEFAULT
Value:
(RES_RECURSE | RES_DEFNAMES | \
RES_DNSRCH)
