radix.h File Reference
struct  radix_node
struct  radix_mask
struct  radix_node_head
#define RNF_NORMAL   1 /* leaf contains normal route */
#define RNF_ROOT   2 /* leaf is root leaf for tree */
#define RNF_ACTIVE   4 /* This node is alive (for rtfree) */
#define rn_dupedkey   rn_u.rn_leaf.rn_Dupedkey
#define rn_key   rn_u.rn_leaf.rn_Key
#define rn_mask   rn_u.rn_leaf.rn_Mask
#define rn_offset   rn_u.rn_node.rn_Off
#define rn_left   rn_u.rn_node.rn_L
#define rn_right   rn_u.rn_node.rn_R
#define rm_mask   rm_rmu.rmu_mask
#define rm_leaf   rm_rmu.rmu_leaf /* extra field would make 32 bytes */
#define MKGet(m)
#define MKFree(m)   { (m)->rm_mklist = rn_mkfreelist; rn_mkfreelist = (m);}
#define Bcmp(a, b, n)   bcmp(((char *)(a)), ((char *)(b)), (n))
#define Bcopy(a, b, n)   bcopy(((char *)(a)), ((char *)(b)), (unsigned)(n))
#define Bzero(p, n)   bzero((char *)(p), (int)(n));
#define R_Malloc(p, t, n)   (p = (t) malloc((unsigned int)(n)))
#define R_Zalloc(p, t, n)   (p = (t) calloc(1,(unsigned int)(n)))
#define Free(p)   free((char *)p);
typedef int walktree_f_t(struct radix_node *, void *)
void rn_init (void)
int rn_inithead (void **, int)
int rn_refines (void *, void *)
struct radix_node * rn_addmask (void *, int, int)
struct radix_node * rn_addroute (void *, void *, struct radix_node_head *, struct radix_node [2])
struct radix_node * rn_delete (void *, void *, struct radix_node_head *)
struct radix_node * rn_lookup (void *v_arg, void *m_arg, struct radix_node_head *head)
struct radix_node * rn_match (void *, struct radix_node_head *)
◆ MKGet
#define MKGet (   m)
Value:
if (rn_mkfreelist) {\
m = rn_mkfreelist; \
rn_mkfreelist = (m)->rm_mklist; \
} else \
R_Malloc(m, struct radix_mask *, sizeof (*(m))); }\
Definition: radix.h:80
