pthreadimpl.h File Reference
POSIX Threads Private Support. More...
#include <rtems/posix/pthread.h>
#include <rtems/posix/config.h>
#include <rtems/posix/threadsup.h>
Include dependency graph for pthreadimpl.h:
#define PTHREAD_MINIMUM_STACK_SIZE   (_Stack_Minimum() * 2)
 The following sets the minimum stack size for POSIX threads.
void _POSIX_Threads_Manager_initialization (void)
 POSIX threads manager initialization. More...
RTEMS_INLINE_ROUTINE void _POSIX_Threads_Copy_attributes (pthread_attr_t *dst_attr, const pthread_attr_t *src_attr)
 Copy POSIX Thread attribute structure. More...
RTEMS_INLINE_ROUTINE void _POSIX_Threads_Free (Thread_Control *the_pthread)
 Free POSIX control block. More...
RTEMS_INLINE_ROUTINE void _POSIX_Threads_Initialize_attributes (pthread_attr_t *attr)
 POSIX threads initialize user threads body. More...
void _POSIX_Threads_Sporadic_budget_callout (Thread_Control *the_thread)
 POSIX threads sporadic budget callout. More...
void _POSIX_Threads_Sporadic_budget_TSR (Objects_Id id, void *argument)
 This routine supports the sporadic scheduling algorithm. More...
int _POSIX_Thread_Translate_sched_param (int policy, struct sched_param *param, Thread_CPU_budget_algorithms *budget_algorithm, Thread_CPU_budget_algorithm_callout *budget_callout)
 Translate sched_param into SuperCore terms. More...
int rtems_pthread_attribute_compare (const pthread_attr_t *attr1, const pthread_attr_t *attr2)
RTEMS_INLINE_ROUTINE Thread_Control * _POSIX_Threads_Allocate (void)
RTEMS_INLINE_ROUTINE bool _POSIX_Threads_Is_null (Thread_Control *the_pthread)
POSIX_EXTERN Objects_Information _POSIX_Threads_Information
 The following defines the information control block used to manage this class of objects.
pthread_attr_t _POSIX_Threads_Default_attributes
 This variable contains the default POSIX Thread attributes.
void(* _POSIX_Threads_Initialize_user_threads_p )(void)
 When the user configures a set of POSIX API initialization threads, This variable will point to the method used to initialize them. More...
This include file contains all the private support information for POSIX threads.
