netdb.h File Reference
#include <sys/cdefs.h>
#include <rtems/bsdnet/_types.h>
Include dependency graph for netdb.h:
struct  hostent
struct  netent
struct  servent
struct  protoent
#define _SOCKLEN_T_DECLARED
#define _PATH_HEQUIV   "/etc/hosts.equiv"
#define _PATH_HOSTS   "/etc/hosts"
#define _PATH_NETWORKS   "/etc/networks"
#define _PATH_PROTOCOLS   "/etc/protocols"
#define _PATH_SERVICES   "/etc/services"
#define h_addr   h_addr_list[0] /* address, for backward compatibility */
#define NETDB_INTERNAL   -1 /* see errno */
#define NETDB_SUCCESS   0 /* no problem */
#define HOST_NOT_FOUND   1 /* Authoritative Answer Host not found */
#define TRY_AGAIN   2 /* Non-Authoritative Host not found, or SERVERFAIL */
#define NO_RECOVERY   3 /* Non recoverable errors, FORMERR, REFUSED, NOTIMP */
#define NO_DATA   4 /* Valid name, no data record of requested type */
#define NO_ADDRESS   NO_DATA /* no address, look for MX record */
typedef __socklen_t socklen_t
__BEGIN_DECLS void endhostent (void)
void endnetent (void)
void endprotoent (void)
void endservent (void)
struct hostent * gethostbyaddr (const void *, socklen_t, int)
struct hostent * gethostbyname (const char *)
struct hostent * gethostbyname2 (const char *, int)
struct hostent * gethostent (void)
struct netent * getnetbyaddr (uint32_t, int)
struct netent * getnetbyname (const char *)
struct netent * getnetent (void)
struct protoent * getprotobyname (const char *)
struct protoent * getprotobynumber (int)
struct protoent * getprotoent (void)
struct servent * getservbyname (const char *, const char *)
struct servent * getservbyport (int, const char *)
struct servent * getservent (void)
void herror (const char *)
__const char * hstrerror (int)
void sethostent (int)
void setnetent (int)
void setprotoent (int)
void setservent (int)
void _sethosthtent (int)
void _endhosthtent (void)
void _sethostdnsent (int)
void _endhostdnsent (void)
void _setnethtent (int)
void _endnethtent (void)
void _setnetdnsent (int)
void _endnetdnsent (void)
struct hostent * _gethostbyhtname (const char *, int)
struct hostent * _gethostbydnsname (const char *, int)
struct hostent * _gethostbynisname (const char *, int)
struct hostent * _gethostbyhtaddr (const char *, int, int)
struct hostent * _gethostbydnsaddr (const char *, int, int)
struct hostent * _gethostbynisaddr (const char *, int, int)
struct netent * _getnetbyhtname (const char *)
struct netent * _getnetbydnsname (const char *)
struct netent * _getnetbynisname (const char *)
struct netent * _getnetbyhtaddr (unsigned long, int)
struct netent * _getnetbydnsaddr (unsigned long, int)
struct netent * _getnetbynisaddr (unsigned long, int)
void _map_v4v6_address (const char *, char *)
void _map_v4v6_hostent (struct hostent *, char **, int *len)
int h_errno
