#define | ARCH_ELFSIZE 32 /* MD native binary size */ |
| #define | ELF32_MACHDEP_ID_CASES |
#define | ELF32_MACHDEP_ID EM_MIPS |
#define | R_MIPS_NONE 0 |
#define | R_MIPS_16 1 |
#define | R_MIPS_32 2 |
#define | R_MIPS_REL32 3 |
#define | R_MIPS_REL R_MIPS_REL32 |
#define | R_MIPS_26 4 |
#define | R_MIPS_HI16 5 /* high 16 bits of symbol value */ |
#define | R_MIPS_LO16 6 /* low 16 bits of symbol value */ |
#define | R_MIPS_GPREL16 7 /* GP-relative reference */ |
#define | R_MIPS_LITERAL 8 /* Reference to literal section */ |
#define | R_MIPS_GOT16 9 /* Reference to global offset table */ |
#define | R_MIPS_GOT R_MIPS_GOT16 |
#define | R_MIPS_PC16 10 /* 16 bit PC relative reference */ |
#define | R_MIPS_CALL16 11 /* 16 bit call thru glbl offset tbl */ |
#define | R_MIPS_CALL R_MIPS_CALL16 |
#define | R_MIPS_GPREL32 12 |
#define | R_MIPS_UNUSED1 13 |
#define | R_MIPS_UNUSED2 14 |
#define | R_MIPS_UNUSED3 15 |
#define | R_MIPS_SHIFT5 16 |
#define | R_MIPS_SHIFT6 17 |
#define | R_MIPS_64 18 |
#define | R_MIPS_GOT_DISP 19 |
#define | R_MIPS_GOT_PAGE 20 |
#define | R_MIPS_GOT_OFST 21 |
#define | R_MIPS_GOT_HI16 22 |
#define | R_MIPS_GOT_LO16 23 |
#define | R_MIPS_SUB 24 |
#define | R_MIPS_INSERT_A 25 |
#define | R_MIPS_INSERT_B 26 |
#define | R_MIPS_DELETE 27 |
#define | R_MIPS_HIGHER 28 |
#define | R_MIPS_HIGHEST 29 |
#define | R_MIPS_CALL_HI16 30 |
#define | R_MIPS_CALL_LO16 31 |
#define | R_MIPS_SCN_DISP 32 |
#define | R_MIPS_REL16 33 |
#define | R_MIPS_ADD_IMMEDIATE 34 |
#define | R_MIPS_PJUMP 35 |
#define | R_MIPS_RELGOT 36 |
#define | R_MIPS_JALR 37 |
#define | R_MIPS_TLS_DTPMOD32 38 /* Module number 32 bit */ |
#define | R_MIPS_TLS_DTPREL32 39 /* Module-relative offset 32 bit */ |
#define | R_MIPS_TLS_DTPMOD64 40 /* Module number 64 bit */ |
#define | R_MIPS_TLS_DTPREL64 41 /* Module-relative offset 64 bit */ |
#define | R_MIPS_TLS_GD 42 /* 16 bit GOT offset for GD */ |
#define | R_MIPS_TLS_LDM 43 /* 16 bit GOT offset for LDM */ |
#define | R_MIPS_TLS_DTPREL_HI16 44 /* Module-relative offset, high 16 bits */ |
#define | R_MIPS_TLS_DTPREL_LO16 45 /* Module-relative offset, low 16 bits */ |
#define | R_MIPS_TLS_GOTTPREL 46 /* 16 bit GOT offset for IE */ |
#define | R_MIPS_TLS_TPREL32 47 /* TP-relative offset, 32 bit */ |
#define | R_MIPS_TLS_TPREL64 48 /* TP-relative offset, 64 bit */ |
#define | R_MIPS_TLS_TPREL_HI16 49 /* TP-relative offset, high 16 bits */ |
#define | R_MIPS_TLS_TPREL_LO16 50 /* TP-relative offset, low 16 bits */ |
#define | R_MIPS_max 51 |
#define | R_TYPE(name) __CONCAT(R_MIPS_,name) |
#define | R_MIPS16_min 100 |
#define | R_MIPS16_26 100 |
#define | R_MIPS16_GPREL 101 |
#define | R_MIPS16_GOT16 102 |
#define | R_MIPS16_CALL16 103 |
#define | R_MIPS16_HI16 104 |
#define | R_MIPS16_LO16 105 |
#define | R_MIPS16_max 106 |
#define | DT_MIPS_RLD_VERSION 0x70000001 |
#define | DT_MIPS_TIME_STAMP 0x70000002 |
#define | DT_MIPS_ICHECKSUM 0x70000003 |
#define | DT_MIPS_IVERSION 0x70000004 |
#define | DT_MIPS_FLAGS 0x70000005 |
#define | DT_MIPS_BASE_ADDRESS 0x70000006 |
#define | DT_MIPS_CONFLICT 0x70000008 |
#define | DT_MIPS_LIBLIST 0x70000009 |
#define | DT_MIPS_CONFLICTNO 0x7000000b |
#define | DT_MIPS_LOCAL_GOTNO 0x7000000a /* number of local got ents */ |
#define | DT_MIPS_LIBLISTNO 0x70000010 |
#define | DT_MIPS_SYMTABNO 0x70000011 /* number of .dynsym entries */ |
#define | DT_MIPS_UNREFEXTNO 0x70000012 |
#define | DT_MIPS_GOTSYM 0x70000013 /* first dynamic sym in got */ |
#define | DT_MIPS_HIPAGENO 0x70000014 |
#define | DT_MIPS_RLD_MAP 0x70000016 /* address of loader map */ |
#define | EF_MIPS_PIC 0x00000002 /* Contains PIC code */ |
#define | EF_MIPS_CPIC 0x00000004 /* STD PIC calling sequence */ |
#define | EF_MIPS_ABI2 0x00000020 /* N32 */ |
#define | EF_MIPS_ARCH_ASE 0x0f000000 /* Architectural extensions */ |
#define | EF_MIPS_ARCH_MDMX 0x08000000 /* MDMX multimedia extension */ |
#define | EF_MIPS_ARCH_M16 0x04000000 /* MIPS-16 ISA extensions */ |
#define | EF_MIPS_ARCH 0xf0000000 /* Architecture field */ |
#define | EF_MIPS_ARCH_1 0x00000000 /* -mips1 code */ |
#define | EF_MIPS_ARCH_2 0x10000000 /* -mips2 code */ |
#define | EF_MIPS_ARCH_3 0x20000000 /* -mips3 code */ |
#define | EF_MIPS_ARCH_4 0x30000000 /* -mips4 code */ |
#define | EF_MIPS_ARCH_5 0x40000000 /* -mips5 code */ |
#define | EF_MIPS_ARCH_32 0x50000000 /* -mips32 code */ |
#define | EF_MIPS_ARCH_64 0x60000000 /* -mips64 code */ |
#define | EF_MIPS_ARCH_32R2 0x70000000 /* -mips32r2 code */ |
#define | EF_MIPS_ARCH_64R2 0x80000000 /* -mips64r2 code */ |
#define | EF_MIPS_ABI 0x0000f000 |
#define | EF_MIPS_ABI_O32 0x00001000 |
#define | EF_MIPS_ABI_O64 0x00002000 |
#define | EF_MIPS_ABI_EABI32 0x00003000 |
#define | EF_MIPS_ABI_EABI64 0x00004000 |
