Macros | Enumerations | Functions | Variables
messageimpl.h File Reference
This include file contains the static inline implementation of all inlined routines in the Message Manager. More...
#include <rtems/rtems/message.h>
Include dependency graph for messageimpl.h:
#define RTEMS_MESSAGE_EXTERN   extern
 This constant is defined to extern most of the time when using this header file. More...
enum  Message_queue_Submit_types { MESSAGE_QUEUE_SEND_REQUEST = 0, MESSAGE_QUEUE_URGENT_REQUEST = 1 }
 The following enumerated type details the modes in which a message may be submitted to a message queue. More...
void _Message_queue_Manager_initialization (void)
 Message Queue Manager Initialization. More...
rtems_status_code _Message_queue_Submit (rtems_id id, const void *buffer, size_t size, Message_queue_Submit_types submit_type)
 Message_queue_Submit. More...
rtems_status_code _Message_queue_Translate_core_message_queue_return_code (uint32_t the_message_queue_status)
 Message queue Translate Core Message Queue Return Code. More...
RTEMS_INLINE_ROUTINE void _Message_queue_Free (Message_queue_Control *the_message_queue)
 Deallocates a message queue control block into the inactive chain of free message queue control blocks. More...
RTEMS_INLINE_ROUTINE Message_queue_Control * _Message_queue_Get (Objects_Id id, Objects_Locations *location)
 Maps message queue IDs to message queue control blocks. More...
RTEMS_INLINE_ROUTINE Message_queue_Control * _Message_queue_Get_interrupt_disable (Objects_Id id, Objects_Locations *location, ISR_lock_Context *lock_context)
RTEMS_INLINE_ROUTINE Message_queue_Control * _Message_queue_Allocate (void)
RTEMS_MESSAGE_EXTERN Objects_Information _Message_queue_Information
 The following defines the information control block used to manage this class of objects.
