RTEMS
6.1
bsps
include
libchip
wd80x3.h
1
9
10
* Information about the DP8390 Ethernet controller.
11
12
13
#ifndef __BSP_WD80x3_h
14
#define __BSP_WD80x3_h
15
16
/* Register descriptions */
17
/* Controller DP8390. */
18
19
#define DATAPORT 0x10
/* Port Window. */
20
#define RESET 0x1f
/* Issue a read for reset */
21
#define W83CREG 0x00
/* I/O port definition */
22
#define ADDROM 0x08
23
24
/* page 0 read or read/write registers */
25
26
#define CMDR 0x00+RO
27
#define CLDA0 0x01+RO
/* current local dma addr 0 for read */
28
#define CLDA1 0x02+RO
/* current local dma addr 1 for read */
29
#define BNRY 0x03+RO
/* boundary reg for rd and wr */
30
#define TSR 0x04+RO
/* tx status reg for rd */
31
#define NCR 0x05+RO
/* number of collision reg for rd */
32
#define FIFO 0x06+RO
/* FIFO for rd */
33
#define ISR 0x07+RO
/* interrupt status reg for rd and wr */
34
#define CRDA0 0x08+RO
/* current remote dma address 0 for rd */
35
#define CRDA1 0x09+RO
/* current remote dma address 1 for rd */
36
#define RSR 0x0C+RO
/* rx status reg for rd */
37
#define CNTR0 0x0D+RO
/* tally cnt 0 for frm alg err for rd */
38
#define CNTR1 RO+0x0E
/* tally cnt 1 for crc err for rd */
39
#define CNTR2 0x0F+RO
/* tally cnt 2 for missed pkt for rd */
40
41
/* page 0 write registers */
42
43
#define PSTART 0x01+RO
/* page start register */
44
#define PSTOP 0x02+RO
/* page stop register */
45
#define TPSR 0x04+RO
/* tx start page start reg */
46
#define TBCR0 0x05+RO
/* tx byte count 0 reg */
47
#define TBCR1 0x06+RO
/* tx byte count 1 reg */
48
#define RSAR0 0x08+RO
/* remote start address reg 0 */
49
#define RSAR1 0x09+RO
/* remote start address reg 1 */
50
#define RBCR0 0x0A+RO
/* remote byte count reg 0 */
51
#define RBCR1 0x0B+RO
/* remote byte count reg 1 */
52
#define RCR 0x0C+RO
/* rx configuration reg */
53
#define TCR 0x0D+RO
/* tx configuration reg */
54
#define DCR RO+0x0E
/* data configuration reg */
55
#define IMR 0x0F+RO
/* interrupt mask reg */
56
57
/* page 1 registers */
58
59
#define PAR 0x01+RO
/* physical addr reg base for rd and wr */
60
#define CURR 0x07+RO
/* current page reg for rd and wr */
61
#define MAR 0x08+RO
/* multicast addr reg base fro rd and WR */
62
#define MARsize 8
/* size of multicast addr space */
63
64
/*-----W83CREG command bits-----*/
65
#define MSK_RESET 0x80
/* W83CREG masks */
66
#define MSK_ENASH 0x40
67
#define MSK_DECOD 0x3F
/* memory decode bits, corresponding */
68
/* to SA 18-13. SA 19 assumed to be 1 */
69
70
/*-----CMDR command bits-----*/
71
#define MSK_STP 0x01
/* stop the chip */
72
#define MSK_STA 0x02
/* start the chip */
73
#define MSK_TXP 0x04
/* initial txing of a frm */
74
#define MSK_RRE 0x08
/* remote read */
75
#define MSK_RWR 0x10
/* remote write */
76
#define MSK_RD2 0x20
/* no DMA used */
77
#define MSK_PG0 0x00
/* select register page 0 */
78
#define MSK_PG1 0x40
/* select register page 1 */
79
#define MSK_PG2 0x80
/* select register page 2 */
80
81
/*-----ISR and TSR status bits-----*/
82
#define MSK_PRX 0x01
/* rx with no error */
83
#define MSK_PTX 0x02
/* tx with no error */
84
#define MSK_RXE 0x04
/* rx with error */
85
#define MSK_TXE 0x08
/* tx with error */
86
#define MSK_OVW 0x10
/* overwrite warning */
87
#define MSK_CNT 0x20
/* MSB of one of the tally counters is set */
88
#define MSK_RDC 0x40
/* remote dma completed */
89
#define MSK_RST 0x80
/* reset state indicator */
90
91
/*-----DCR command bits-----*/
92
#define MSK_WTS 0x01
/* word transfer mode selection */
93
#define MSK_BOS 0x02
/* byte order selection */
94
#define MSK_LAS 0x04
/* long addr selection */
95
#define MSK_BMS 0x08
/* burst mode selection */
96
#define MSK_ARM 0x10
/* autoinitialize remote */
97
#define MSK_FT00 0x00
/* burst lrngth selection */
98
#define MSK_FT01 0x20
99
#define MSK_FT10 0x40
100
#define MSK_FT11 0x60
101
102
/*-----RCR command bits-----*/
103
#define MSK_SEP 0x01
/* save error pkts */
104
#define MSK_AR 0x02
/* accept runt pkt */
105
#define MSK_AB 0x04
/* 8390 RCR */
106
#define MSK_AM 0x08
/* accept multicast */
107
#define MSK_PRO 0x10
/* accept all pkt with physical adr */
108
#define MSK_MON 0x20
/* monitor mode */
109
110
/*-----TCR command bits-----*/
111
#define MSK_CRC 0x01
/* inhibit CRC, do not append crc */
112
#define MSK_LOOP 0x02
/* set loopback mode */
113
#define MSK_BCST 0x04
/* Accept broadcasts */
114
#define MSK_LB01 0x06
/* encoded loopback control */
115
#define MSK_ATD 0x08
/* auto tx disable */
116
#define MSK_OFST 0x10
/* collision offset enable */
117
118
/*-----receive status bits-----*/
119
#define SMK_PRX 0x01
/* rx without error */
120
#define SMK_CRC 0x02
/* CRC error */
121
#define SMK_FAE 0x04
/* frame alignment error */
122
#define SMK_FO 0x08
/* FIFO overrun */
123
#define SMK_MPA 0x10
/* missed pkt */
124
#define SMK_PHY 0x20
/* physical/multicase address */
125
#define SMK_DIS 0x40
/* receiver disable. set in monitor mode */
126
#define SMK_DEF 0x80
/* deferring */
127
128
/*-----transmit status bits-----*/
129
#define SMK_PTX 0x01
/* tx without error */
130
#define SMK_DFR 0x02
/* non deferred tx */
131
#define SMK_COL 0x04
/* tx collided */
132
#define SMK_ABT 0x08
/* tx abort because of excessive collisions */
133
#define SMK_CRS 0x10
/* carrier sense lost */
134
#define SMK_FU 0x20
/* FIFO underrun */
135
#define SMK_CDH 0x40
/* collision detect heartbeat */
136
#define SMK_OWC 0x80
/* out of window collision */
137
138
#endif
139
/* end of include */
