RTEMS 6.1
versal-uart.h
2
11/*
12 * Copyright (C) 2021 Gedare Bloom <gedare@rtems.org>
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_XILINX_VERSAL_UART_H
37#define LIBBSP_ARM_XILINX_VERSAL_UART_H
38
39#include <rtems/termiostypes.h>
42
43#ifdef __cplusplus
44extern "C" {
45#endif /* __cplusplus */
46
56typedef struct {
57 arm_pl011_context pl011_ctx;
58 volatile bool transmitting;
60
61extern const rtems_termios_device_handler versal_uart_handler;
62
63#define VERSAL_UART_DEFAULT_BAUD 115200
64
65int versal_uart_initialize(rtems_termios_device_context *base);
66
67void versal_uart_reset_tx_flush(rtems_termios_device_context *base);
68
69#ifdef __cplusplus
70}
71#endif /* __cplusplus */
72
73#endif /* LIBBSP_ARM_XILINX_VERSAL_UART_H */
ARM PL011 Register definitions.
ARM PL011 Support Package.
Definition: arm-pl011.h:66
Termios device context.
Definition: termiosdevice.h:68
Termios device handler.
Definition: termiosdevice.h:100
Definition: versal-uart.h:56
