RTEMS 6.1
aml_resource Union Reference
UINT8 DescriptorType
AML_RESOURCE_SMALL_HEADER SmallHeader
AML_RESOURCE_LARGE_HEADER LargeHeader
AML_RESOURCE_IRQ Irq
AML_RESOURCE_DMA Dma
AML_RESOURCE_START_DEPENDENT StartDpf
AML_RESOURCE_END_DEPENDENT EndDpf
AML_RESOURCE_IO Io
AML_RESOURCE_FIXED_IO FixedIo
AML_RESOURCE_FIXED_DMA FixedDma
AML_RESOURCE_VENDOR_SMALL VendorSmall
AML_RESOURCE_END_TAG EndTag
AML_RESOURCE_MEMORY24 Memory24
AML_RESOURCE_GENERIC_REGISTER GenericReg
AML_RESOURCE_VENDOR_LARGE VendorLarge
AML_RESOURCE_MEMORY32 Memory32
AML_RESOURCE_FIXED_MEMORY32 FixedMemory32
AML_RESOURCE_ADDRESS16 Address16
AML_RESOURCE_ADDRESS32 Address32
AML_RESOURCE_ADDRESS64 Address64
AML_RESOURCE_EXTENDED_ADDRESS64 ExtAddress64
AML_RESOURCE_EXTENDED_IRQ ExtendedIrq
AML_RESOURCE_GPIO Gpio
AML_RESOURCE_I2C_SERIALBUS I2cSerialBus
AML_RESOURCE_SPI_SERIALBUS SpiSerialBus
AML_RESOURCE_UART_SERIALBUS UartSerialBus
AML_RESOURCE_CSI2_SERIALBUS Csi2SerialBus
AML_RESOURCE_COMMON_SERIALBUS CommonSerialBus
AML_RESOURCE_PIN_FUNCTION PinFunction
AML_RESOURCE_PIN_CONFIG PinConfig
AML_RESOURCE_PIN_GROUP PinGroup
AML_RESOURCE_PIN_GROUP_FUNCTION PinGroupFunction
AML_RESOURCE_PIN_GROUP_CONFIG PinGroupConfig
AML_RESOURCE_CLOCK_INPUT ClockInput
AML_RESOURCE_ADDRESS Address
UINT32 DwordItem
UINT16 WordItem
UINT8 ByteItem
The documentation for this union was generated from the following file:
