RTEMS 6.1
SWT_CR_32B_tag Union Reference
uint32_t R
struct {
   uint32_t   MAP0:1
   uint32_t   MAP1:1
   uint32_t   MAP2:1
   uint32_t   MAP3:1
   uint32_t   MAP4:1
   uint32_t   MAP5:1
   uint32_t   MAP6:1
   uint32_t   MAP7:1
   uint32_t   __pad0__:14
   uint32_t   KEY:1
   uint32_t   RIA:1
   uint32_t   WND:1
   uint32_t   ITR:1
   uint32_t   HLK:1
   uint32_t   SLK:1
   uint32_t   __pad1__:1
   uint32_t   STP:1
   uint32_t   FRZ:1
   uint32_t   WEN:1
B
The documentation for this union was generated from the following file:
