RTEMS 6.1
uart-bridge.h
2
11/*
12 * Copyright (C) 2011, 2015 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_POWERPC_QORIQ_UART_BRIDGE_H
37#define LIBBSP_POWERPC_QORIQ_UART_BRIDGE_H
38
39#include <rtems/termiosdevice.h>
40
41#include <bsp/intercom.h>
42
43#ifdef __cplusplus
44extern "C" {
45#endif /* __cplusplus */
46
57typedef struct {
59 const char *device_path;
60 intercom_type type;
61 rtems_id transmit_task;
62 rtems_chain_control transmit_fifo;
64
65typedef struct {
67 struct rtems_termios_tty *tty;
68 intercom_type type;
69 rtems_id transmit_task;
70 rtems_chain_control transmit_fifo;
72
73bool qoriq_uart_bridge_master_probe(rtems_termios_device_context *base);
74
75extern const rtems_termios_device_handler qoriq_uart_bridge_master;
76
77extern const rtems_termios_device_handler qoriq_uart_bridge_slave;
78
81#ifdef __cplusplus
82}
83#endif /* __cplusplus */
84
85#endif /* LIBBSP_POWERPC_QORIQ_UART_BRIDGE_H */
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
Inter-Processor Communication API.
Termios device context.
Definition: termiosdevice.h:68
Termios device handler.
Definition: termiosdevice.h:100
Definition: termiostypes.h:94
Definition: uart-bridge.h:57
Definition: uart-bridge.h:65
This header file provides the interfaces of the RTEMS Termios Device Support.
This union represents a chain control block.
Definition: chain.h:96
