RTEMS 6.1
u-boot.h
2
11/*
12 * Copyright (C) 2010, 2014 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_SHARED_U_BOOT_H
37#define LIBBSP_SHARED_U_BOOT_H
38
39#include <bsp/u-boot-config.h>
40
41#include <sys/types.h>
42#include <stdint.h>
43
44#ifdef U_BOOT_64_BIT_PHYS_SIZE
45 typedef uint64_t phys_size_t;
46#else
47 typedef unsigned long phys_size_t;
48#endif
49
50#include <bsp/u-boot-board-info.h>
51
52#ifdef __cplusplus
53extern "C" {
54#endif /* __cplusplus */
55
56extern bd_t bsp_uboot_board_info;
57
66void bsp_uboot_copy_board_info(const bd_t *src);
67
68/* FIXME: Do not use this function */
69void dumpUBootBDInfo(bd_t *u);
70
71#ifdef __cplusplus
72}
73#endif /* __cplusplus */
74
75#endif /* LIBBSP_SHARED_U_BOOT_H */
Definition: u-boot-board-info.h:39
