RTEMS 6.1
tx4938.h File Reference
#define TX4938_REG_BASE   0xFF1F0000
#define TX4938_PCI1_PCIID   0x7000
#define TX4938_PCI1_PCISTATUS   0x7004
#define TX4938_PCI1_PCICFG1   0x700c
#define TX4938_PCI1_P2GM1PLBASE   0x7018
#define TX4938_PCI1_P2GCFG   0x7090
#define TX4938_PCI1_PBAREQPORT   0x7100
#define TX4938_PCI1_PBACFG   0x7104
#define TX4938_PCI1_G2PM0GBASE   0x7120
#define TX4938_PCI1_G2PIOGBASE   0x7138
#define TX4938_PCI1_G2PM0MASK   0x7140
#define TX4938_PCI1_G2PIOMASK   0x714c
#define TX4938_PCI1_G2PM0PBASE   0x7150
#define TX4938_PCI1_G2PIOPBASE   0x7168
#define TX4938_PCI1_PCICCFG   0x7170
#define TX4938_PCI1_PCICSTATUS   0x7174
#define TX4938_PCI1_P2GM1GBASE   0x7188
#define TX4938_PCI1_G2PCFGADRS   0x71a0
#define TX4938_PCI1_G2PCFGDATA   0x71a4
#define TX4938_CFG_CCFG   0xE000 /* Chip Configuration Register */
#define TX4938_CFG_REVID   0xE008 /* Chip Revision ID Register */
#define TX4938_CFG_PCFG   0xE010 /* Pin Configuration Register */
#define TX4938_CFG_TOEA   0xE018 /* TimeOut Error Access Address Register */
#define TX4938_CFG_CLKCTR   0xE020 /* Clock Control Register */
#define TX4938_CFG_GARBC   0xE030 /* GBUS Arbiter Control Register */
#define TX4938_CFG_RAMP   0xE048 /* Register Address Mapping Register */
#define SELCHI   0x00100000
#define SELTMR0   0x00000200
#define TX4938_TIMER0_BASE   0xF000
#define TX4938_TIMER1_BASE   0xF100
#define TX4938_TIMER2_BASE   0xF200
#define TX4938_TIMER_TCR   0x00 /* Timer Control Register */
#define TX4938_TIMER_TISR   0x04 /* Timer Interrupt Status Register */
#define TX4938_TIMER_CPRA   0x08 /* Compare Register A */
#define TX4938_TIMER_CPRB   0x0C /* Compare Register B */
#define TX4938_TIMER_ITMR   0x10 /* Interval Timer Mode Register */
#define TX4938_TIMER_CCDR   0x20 /* Divide Cycle Register */
#define TX4938_TIMER_PGMR   0x30 /* Pulse Generator Mode Register */
#define TX4938_TIMER_WTMR   0x40 /* Reserved Register */
#define TX4938_TIMER_TRR   0xF0 /* Timer Read Register */
#define TIMER_CLEAR_ENABLE_MASK   0x1
#define TIMER_INT_ENABLE_MASK   0x8000
#define FFI   0x1
#define TPIAE   0x4000
#define TPIBE   0x8000
#define TIIS   0x1
#define TPIAS   0x2
#define TPIBS   0x4
#define TWIS   0x8
#define TX4938_IRQCTL_DEN   0xF600 /* Interrupt Detection Enable Register */
#define TX4938_IRQCTL_DM0   0xF604 /* Interrupt Detection Mode Register 0 */
#define TX4938_IRQCTL_DM1   0xF608 /* Interrupt Detection Mode Register 1 */
#define TX4938_IRQCTL_LVL0   0xF610 /* Interrupt Level Register 0 */
#define TX4938_IRQCTL_LVL1   0xF614 /* Interrupt Level Register 1 */
#define TX4938_IRQCTL_LVL2   0xF618 /* Interrupt Level Register 2 */
#define TX4938_IRQCTL_LVL3   0xF61C /* Interrupt Level Register 3 */
#define TX4938_IRQCTL_LVL4   0xF620 /* Interrupt Level Register 4 */
#define TX4938_IRQCTL_LVL5   0xF624 /* Interrupt Level Register 5 */
#define TX4938_IRQCTL_LVL6   0xF628 /* Interrupt Level Register 6 */
#define TX4938_IRQCTL_LVL7   0xF62C /* Interrupt Level Register 7 */
#define TX4938_IRQCTL_MSK   0xF640 /* Interrupt Mask Register */
#define TX4938_IRQCTL_EDC   0xF660 /* Interrupt Edge Detection Clear Register */
#define TX4938_IRQCTL_PND   0xF680 /* Interrupt Pending Register */
#define TX4938_IRQCTL_CS   0xF6A0 /* Interrupt Current Status Register */
#define TX4938_IRQCTL_FLAG0   0xF510 /* Interrupt Request Flag Register 0 */
#define TX4938_IRQCTL_FLAG1   0xF514 /* Interrupt Request Flag Register 1 */
#define TX4938_IRQCTL_POL   0xF518 /* Interrupt Request Polarity Control Register */
#define TX4938_IRQCTL_RCNT   0xF51C /* Interrupt Request Control Register */
#define TX4938_IRQCTL_MASKINT   0xF520 /* Interrupt Request Internal Interrupt Mask Register */
#define TX4938_IRQCTL_MASKEXT   0xF524 /* Interrupt Request External Interrupt Mask Register */
#define TX4938_REG_READ(_base, _register)    *((volatile uint32_t *)((_base) + (_register)))
#define TX4938_REG_WRITE(_base, _register, _value)    *((volatile uint32_t *)((_base) + (_register))) = (_value)
#define TX4938_CCFG_SYSSP_SHF   6
#define TX4938_CCFG_SYSSP_MSK   (MSK(2) << TX4938_CCFG_SYSSP_SHF)
#define TX4938_CCFG_PCI1DMD_SHF   8
#define TX4938_CCFG_PCI1DMD_MSK   (MSK(1) << TX4938_CCFG_PCI1DMD_SHF)
#define TX4938_CCFG_PCIDIVMODE_SHF   10
#define TX4938_CCFG_PCIDIVMODE_MSK   (MSK(3) << TX4938_CCFG_PCIDIVMODE_SHF)
#define TX4938_CCFG_PCI166_SHF   21
#define TX4938_CCFG_PCI166_MSK   ((UINT64)MSK(1) << TX4938_CCFG_PCI166_SHF)
#define TX4938_CCFG_PCIMODE_SHF   22
#define TX4938_CCFG_PCIMODE_MSK   ((UINT64)MSK(1) << TX4938_CCFG_PCIMODE_SHF)
#define TX4938_CCFG_BRDTY_SHF   36
#define TX4938_CCFG_RRDTY_MSK   ((UINT64)MSK(4) << TX4938_CCFG_BRDTY_SHF)
#define TX4938_CCFG_BRDRV_SHF   32
#define TX4938_CCFG_BRDRV_MSK   ((UINT64)MSK(4) << TX4938_CCFG_BRDRV_SHF)
#define TX4938_CLKCTR_PCIC1RST_SHF   11
#define TX4938_CLKCTR_PCIC1RST_MSK   (MSK(1) << TX4938_CLKCTR_PCIC1RST_SHF)
#define TX4938_PCI_PCISTATUS_MEMSP_SHF   1
#define TX4938_PCI_PCISTATUS_MEMSP_MSK   (MSK(1) << TX4938_PCI_PCISTATUS_MEMSP_SHF)
#define TX4938_PCI_PCISTATUS_BM_SHF   2
#define TX4938_PCI_PCISTATUS_BM_MSK   (MSK(1) << TX4938_PCI_PCISTATUS_BM_SHF)
#define TX4938_PCI_PBACFG_RPBA_SHF   2
#define TX4938_PCI_PBACFG_RPBA_MSK   (MSK(1) << TX4938_PCI_PBACFG_RPBA_SHF)
#define TX4938_PCI_PBACFG_PBAEN_SHF   1
#define TX4938_PCI_PBACFG_PBAEN_MSK   (MSK(1) << TX4938_PCI_PBACFG_PBAEN_SHF)
#define TX4938_PCI_PCICFG_G2PM0EN_SHF   6
#define TX4938_PCI_PCICFG_G2PM0EN_MSK   (MSK(1) << TX4938_PCI_PCICFG_G2PM0EN_SHF)
#define TX4938_PCI_PCICFG_G2PIOEN_SHF   5
#define TX4938_PCI_PCICFG_G2PIOEN_MSK   (MSK(1) << TX4938_PCI_PCICFG_G2PIOEN_SHF)
#define TX4938_PCI_PCICFG_TCAR_SHF   4
#define TX4938_PCI_PCICFG_TCAR_MSK   (MSK(1) << TX4938_PCI_PCICFG_TCAR_SHF)
MIPS Tx4938 specific information
