RTEMS 6.1
This source file contains the implementation of support functions for the validation test cases. More...
#include "tx-support.h"#include "ts-config.h"#include <rtems/test.h>#include <rtems/score/percpu.h>#include <rtems/score/smpimpl.h>#include <rtems/score/threaddispatch.h>#include <rtems/score/threadimpl.h>#include <rtems/rtems/semimpl.h>#include <string.h>Functions | |
| rtems_id | DoCreateTask (rtems_name name, rtems_task_priority priority) |
| void | StartTask (rtems_id id, rtems_task_entry entry, void *arg) |
| void | DeleteTask (rtems_id id) |
| void | SuspendTask (rtems_id id) |
| void | SuspendSelf (void) |
| void | ResumeTask (rtems_id id) |
| bool | IsTaskSuspended (rtems_id id) |
| rtems_event_set | QueryPendingEvents (void) |
| rtems_event_set | PollAnyEvents (void) |
| rtems_event_set | ReceiveAnyEvents (void) |
| rtems_event_set | ReceiveAnyEventsTimed (rtems_interval ticks) |
| void | ReceiveAllEvents (rtems_event_set events) |
| void | SendEvents (rtems_id id, rtems_event_set events) |
| rtems_mode | GetMode (void) |
| rtems_mode | SetMode (rtems_mode set, rtems_mode mask) |
| rtems_task_priority | GetPriority (rtems_id id) |
| rtems_task_priority | GetPriorityByScheduler (rtems_id task_id, rtems_id scheduler_id) |
| rtems_task_priority | SetPriority (rtems_id id, rtems_task_priority priority) |
| rtems_task_priority | GetSelfPriority (void) |
| rtems_task_priority | SetSelfPriority (rtems_task_priority priority) |
| rtems_task_priority | SetSelfPriorityNoYield (rtems_task_priority priority) |
| rtems_id | GetScheduler (rtems_id id) |
| rtems_id | GetSelfScheduler (void) |
| void | SetScheduler (rtems_id task_id, rtems_id scheduler_id, rtems_task_priority priority) |
| void | SetSelfScheduler (rtems_id scheduler_id, rtems_task_priority priority) |
| void | GetAffinity (rtems_id id, cpu_set_t *set) |
| void | GetSelfAffinity (cpu_set_t *set) |
| void | SetAffinity (rtems_id id, const cpu_set_t *set) |
| void | SetSelfAffinity (const cpu_set_t *set) |
| void | SetAffinityOne (rtems_id id, uint32_t cpu_index) |
| void | SetSelfAffinityOne (uint32_t cpu_index) |
| void | SetAffinityAll (rtems_id id) |
| void | SetSelfAffinityAll (void) |
| void | Yield (void) |
| void | YieldTask (rtems_id id) |
| void | AddProcessor (rtems_id scheduler_id, uint32_t cpu_index) |
| void | RemoveProcessor (rtems_id scheduler_id, uint32_t cpu_index) |
| rtems_id | CreateMutex (void) |
| rtems_id | CreateMutexNoProtocol (void) |
| rtems_id | CreateMutexFIFO (void) |
| void | DeleteMutex (rtems_id id) |
| bool | IsMutexOwner (rtems_id id) |
| void | ObtainMutex (rtems_id id) |
| void | ObtainMutexTimed (rtems_id id, rtems_interval ticks) |
| void | ObtainMutexDeadlock (rtems_id id) |
| void | ReleaseMutex (rtems_id id) |
| Thread_queue_Queue * | GetMutexThreadQueue (rtems_id id) |
| void | RestoreRunnerASR (void) |
| void | RestoreRunnerMode (void) |
| void | RestoreRunnerPriority (void) |
| void | RestoreRunnerScheduler (void) |
| Thread_Control * | GetThread (rtems_id id) |
| Thread_Control * | GetExecuting (void) |
| void | KillZombies (void) |
| void | WaitForExecutionStop (rtems_id task_id) |
| void | WaitForIntendToBlock (rtems_id task_id) |
| void | WaitForHeir (uint32_t cpu_index, rtems_id task_id) |
| void | WaitForNextTask (uint32_t cpu_index, rtems_id task_id) |
| void | GetTaskTimerInfo (rtems_id id, TaskTimerInfo *info) |
| void | GetTaskTimerInfoByThread (struct _Thread_Control *thread, TaskTimerInfo *info) |
| void | ClockTick (void) |
| void | FinalClockTick (void) |
| Simulates a clock tick with the final expire time point of UINT64_MAX for all clocks. | |
| void | FatalInitialExtension (rtems_fatal_source source, bool always_set_to_false, rtems_fatal_code code) |
| void | SetFatalHandler (FatalHandler fatal, void *arg) |
| void | SetTaskSwitchExtension (rtems_task_switch_extension task_switch) |
| void | ClearExtensionCalls (ExtensionCalls *calls) |
| void | CopyExtensionCalls (const ExtensionCalls *from, ExtensionCalls *to) |
| void | StartDelayThreadDispatch (uint32_t cpu_index) |
| void | StopDelayThreadDispatch (uint32_t cpu_index) |
| bool | AreInterruptsEnabled (void) |
| bool | IsWhiteSpaceOnly (const char *s) |
| bool | IsEqualIgnoreWhiteSpace (const char *a, const char *b) |
