RTEMS 6.1
tr-tq-surrender-mrsp.h
2
9/*
10 * Copyright (C) 2021 embedded brains GmbH & Co. KG
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 * POSSIBILITY OF SUCH DAMAGE.
32 */
33
34/*
35 * This file is part of the RTEMS quality process and was automatically
36 * generated. If you find something that needs to be fixed or
37 * worded better please post a report or patch to an RTEMS mailing list
38 * or raise a bug report:
39 *
40 * https://www.rtems.org/bugs.html
41 *
42 * For information on updating and regenerating please refer to the How-To
43 * section in the Software Requirements Engineering chapter of the
44 * RTEMS Software Engineering manual. The manual is provided as a part of
45 * a release. For development sources please refer to the online
46 * documentation at:
47 *
48 * https://docs.rtems.org
49 */
50
51#ifndef _TR_TQ_SURRENDER_MRSP_H
52#define _TR_TQ_SURRENDER_MRSP_H
53
54#include "tx-thread-queue.h"
55
56#ifdef __cplusplus
57extern "C" {
58#endif
59
66typedef enum {
67 ScoreTqReqSurrenderMrsp_Pre_InheritedPriority_Vital,
68 ScoreTqReqSurrenderMrsp_Pre_InheritedPriority_Dispensable,
69 ScoreTqReqSurrenderMrsp_Pre_InheritedPriority_NA
70} ScoreTqReqSurrenderMrsp_Pre_InheritedPriority;
71
72typedef enum {
73 ScoreTqReqSurrenderMrsp_Pre_PreviousHelping_Vital,
74 ScoreTqReqSurrenderMrsp_Pre_PreviousHelping_Dispensable,
75 ScoreTqReqSurrenderMrsp_Pre_PreviousHelping_NA
76} ScoreTqReqSurrenderMrsp_Pre_PreviousHelping;
77
78typedef enum {
79 ScoreTqReqSurrenderMrsp_Pre_Scheduler_Home,
80 ScoreTqReqSurrenderMrsp_Pre_Scheduler_Helping,
81 ScoreTqReqSurrenderMrsp_Pre_Scheduler_NA
82} ScoreTqReqSurrenderMrsp_Pre_Scheduler;
83
84typedef enum {
85 ScoreTqReqSurrenderMrsp_Pre_NewHelping_Vital,
86 ScoreTqReqSurrenderMrsp_Pre_NewHelping_Dispensable,
87 ScoreTqReqSurrenderMrsp_Pre_NewHelping_NA
88} ScoreTqReqSurrenderMrsp_Pre_NewHelping;
89
90typedef enum {
91 ScoreTqReqSurrenderMrsp_Pre_Suspended_Yes,
92 ScoreTqReqSurrenderMrsp_Pre_Suspended_No,
93 ScoreTqReqSurrenderMrsp_Pre_Suspended_NA
94} ScoreTqReqSurrenderMrsp_Pre_Suspended;
95
96typedef enum {
97 ScoreTqReqSurrenderMrsp_Pre_WaitState_IntendToBlock,
98 ScoreTqReqSurrenderMrsp_Pre_WaitState_NA
99} ScoreTqReqSurrenderMrsp_Pre_WaitState;
100
101typedef enum {
102 ScoreTqReqSurrenderMrsp_Post_Dequeue_Priority,
103 ScoreTqReqSurrenderMrsp_Post_Dequeue_NA
104} ScoreTqReqSurrenderMrsp_Post_Dequeue;
105
106typedef enum {
107 ScoreTqReqSurrenderMrsp_Post_Unblock_No,
108 ScoreTqReqSurrenderMrsp_Post_Unblock_NA
109} ScoreTqReqSurrenderMrsp_Post_Unblock;
110
111typedef enum {
112 ScoreTqReqSurrenderMrsp_Post_PreviousOwnerPriority_Drop,
113 ScoreTqReqSurrenderMrsp_Post_PreviousOwnerPriority_Nop,
114 ScoreTqReqSurrenderMrsp_Post_PreviousOwnerPriority_NA
115} ScoreTqReqSurrenderMrsp_Post_PreviousOwnerPriority;
116
117typedef enum {
118 ScoreTqReqSurrenderMrsp_Post_RemoveHelper_Yes,
119 ScoreTqReqSurrenderMrsp_Post_RemoveHelper_No,
120 ScoreTqReqSurrenderMrsp_Post_RemoveHelper_NA
121} ScoreTqReqSurrenderMrsp_Post_RemoveHelper;
122
123typedef enum {
124 ScoreTqReqSurrenderMrsp_Post_AddHelper_Yes,
125 ScoreTqReqSurrenderMrsp_Post_AddHelper_No,
126 ScoreTqReqSurrenderMrsp_Post_AddHelper_NA
127} ScoreTqReqSurrenderMrsp_Post_AddHelper;
128
129typedef enum {
130 ScoreTqReqSurrenderMrsp_Post_Suspended_Yes,
131 ScoreTqReqSurrenderMrsp_Post_Suspended_No,
132 ScoreTqReqSurrenderMrsp_Post_Suspended_NA
133} ScoreTqReqSurrenderMrsp_Post_Suspended;
134
141
144#ifdef __cplusplus
145}
146#endif
147
148#endif /* _TR_TQ_SURRENDER_MRSP_H */
void ScoreTqReqSurrenderMrsp_Run(TQContext *tq_ctx)
Runs the parameterized test case.
Definition: tr-tq-surrender-mrsp.c:982
Definition: tx-thread-queue.h:148
This header file provides the functions to test the Thread Queue Handler.
