RTEMS 6.1
#include <rtems.h>#include <rtems/rtems/tasksdata.h>#include "tr-fatal-init-task-construct-failed.h"#include <rtems/test.h>Data Structures | |
| struct | AcfgValFatalInitTaskConstructFailed_Context |
| Test context for spec:/acfg/val/fatal-init-task-construct-failed test case. More... | |
| void | AcfgValFatalInitTaskConstructFailed_Run (rtems_fatal_source source, rtems_fatal_code code) |
| Runs the parameterized test case. | |
