RTEMS 6.1
tqm.h
2
3/*
4 * RTEMS BSP support for TQ modules
5 *
6 * This file contains definitions to interact with TQC's
7 * processor modules.
8 */
9
10/*
11 * Copyright (c) 2007 embedded brains GmbH & Co. KG
12 *
13 * Redistribution and use in source and binary forms, with or without
14 * modification, are permitted provided that the following conditions
15 * are met:
16 * 1. Redistributions of source code must retain the above copyright
17 * notice, this list of conditions and the following disclaimer.
18 * 2. Redistributions in binary form must reproduce the above copyright
19 * notice, this list of conditions and the following disclaimer in the
20 * documentation and/or other materials provided with the distribution.
21 *
22 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
23 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
24 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
25 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
26 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
27 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
28 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
29 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
30 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
31 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
32 * POSSIBILITY OF SUCH DAMAGE.
33 */
34
35#ifndef __TQM_H__
36#define __TQM_H__
37#include <rtems.h>
38
39typedef struct {
40 uint32_t sdram_size; /* existing SDRAM size */
41 uint32_t flash_base; /* start address flash */
42 uint32_t flash_size; /* existing Flash size */
43 uint32_t flash_offset;
44 uint32_t sram_base; /* start address sram */
45 uint32_t sram_size; /* existing sram size */
46 uint32_t immr_base; /* start address internal memory map */
47 uint32_t reboot; /* reboot flag */
48 uint8_t ip_addr[4]; /* IP address */
49 uint8_t eth_addr[6]; /* ethernet (MAC) address */
50 uint8_t gap_42[2]; /* gap for alignment */
51 void (*put_char)(int c); /* function to output characters */
53
54#define TQM_BD_INFO_ADDR 0x3400
55#define TQM_BD_INFO (*(tqm_bd_info_t *)TQM_BD_INFO_ADDR)
56
57#define TQM_CONF_INFO_BLOCK_ADDR 0x4001fe00
58
59#define IMAP_ADDR ((unsigned int)0xfa200000)
60#define IMAP_SIZE ((unsigned int)(64 * 1024))
61
62#endif /* __TQM_H__ */
Definition: tqm.h:39
