RTEMS 6.1
tms570-sci-driver.h
2
11/*
12 * Copyright (C) 2014 Premysl Houdek <kom541000@gmail.com>
13 *
14 * Google Summer of Code 2014 at
15 * Czech Technical University in Prague
16 * Zikova 1903/4
17 * 166 36 Praha 6
18 * Czech Republic
19 *
20 * Redistribution and use in source and binary forms, with or without
21 * modification, are permitted provided that the following conditions
22 * are met:
23 * 1. Redistributions of source code must retain the above copyright
24 * notice, this list of conditions and the following disclaimer.
25 * 2. Redistributions in binary form must reproduce the above copyright
26 * notice, this list of conditions and the following disclaimer in the
27 * documentation and/or other materials provided with the distribution.
28 *
29 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
30 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
31 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
32 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
33 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
34 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
35 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
36 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
37 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
38 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
39 * POSSIBILITY OF SUCH DAMAGE.
40 */
41
42#ifndef TMS570_SCI_DRIVER
43#define TMS570_SCI_DRIVER
44
45#include <rtems/termiostypes.h>
46#include <rtems/irq.h>
47#include <bsp/tms570.h>
48
49#ifdef __cplusplus
50extern "C" {
51#endif /* __cplusplus */
52
53/* Low-level driver specific data structure */
54typedef struct {
56 const char *device_name;
57 volatile tms570_sci_t *regs;
58 int tx_chars_in_hw;
61
63
65
67
68void tms570_sci_initialize(tms570_sci_context *ctx);
69
72 const struct termios *term
73);
74
77#ifdef __cplusplus
78}
79#endif /* __cplusplus */
80
81#endif /* TMS570_SCI_DRIVER */
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition: intr.h:102
Termios device context.
Definition: termiosdevice.h:68
Termios device handler.
Definition: termiosdevice.h:100
Definition: tms570-sci-driver.h:54
Definition: reg_sci.h:54
const rtems_termios_device_handler tms570_sci_handler_polled
Struct containing definitions of polled driver functions.
Definition: tms570-sci.c:609
tms570_sci_context driver_context_table[]
Table including all serial drivers.
Definition: tms570-sci.c:57
bool tms570_sci_set_attributes(rtems_termios_device_context *base, const struct termios *term)
Set attributes of the HW peripheral.
Definition: tms570-sci.c:232
const rtems_termios_device_handler tms570_sci_handler_interrupt
Struct containing definitions of interrupt driven driver functions.
Definition: tms570-sci.c:624
This header file provides TMS570 interfaces.
