RTEMS 6.1
timetick.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
51#ifndef _TIMETICK_
52#define _TIMETICK_
53
54/*----------------------------------------------------------------------------
55 * Headers
56 *----------------------------------------------------------------------------*/
57
58#include <stdint.h>
59
60/*----------------------------------------------------------------------------
61 * Definitions
62 *----------------------------------------------------------------------------*/
63
64typedef struct {
65 volatile uint32_t *pTimer1;
66 volatile uint32_t *pTimer2;
67 volatile uint32_t *pTimer3;
68 volatile uint32_t *pTimer4;
70
71/*----------------------------------------------------------------------------
72 * Definitions
73 *----------------------------------------------------------------------------*/
74typedef struct _TimeEvent {
75 uint32_t event;
76 uint32_t time_tick;
77 uint32_t time_start;
78 uint32_t occur;
79 struct _TimeEvent *pPreEvent;
80 struct _TimeEvent *pNextEvent;
81} TimeEvent;
82
83/*----------------------------------------------------------------------------
84 * Global functions
85 *----------------------------------------------------------------------------*/
86
87uint32_t TimeTick_Configure(void);
88
89void TimeTick_Increment(uint32_t dwInc);
90
91uint32_t GetDelayInTicks(uint32_t startTick, uint32_t endTick);
92
93uint32_t GetTicks(void);
94
95void Wait(volatile uint32_t dwMs);
96
97void Sleep(volatile uint32_t dwMs);
98
99extern void SetTimeEvent(TimeEvent *pEvent);
100
101#endif /* _TIMETICK_ */
Definition: timetick.h:64
Definition: timetick.h:74
