RTEMS 6.1
threadidledata.h
1
11/*
12 * SPDX-License-Identifier: BSD-2-Clause
13 *
14 * Copyright (C) 2020 embedded brains GmbH & Co. KG
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in the
23 * documentation and/or other materials provided with the distribution.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35 * POSSIBILITY OF SUCH DAMAGE.
36 */
37
38#ifndef _RTEMS_SCORE_THREADIDLEDATA_H
39#define _RTEMS_SCORE_THREADIDLEDATA_H
40
42
43#ifdef __cplusplus
44extern "C" {
45#endif
46
59extern const size_t _Thread_Idle_stack_size;
60
64typedef void *( *Thread_Idle_body )( uintptr_t );
65
73
76#ifdef __cplusplus
77}
78#endif
79
80#endif /* _RTEMS_SCORE_THREADIDLEDATA_H */
This header file provides basic definitions used by the API and the implementation.
void *(* Thread_Idle_body)(uintptr_t)
The idle thread body type.
Definition: threadidledata.h:64
const Thread_Idle_body _Thread_Idle_body
The idle thread body.
Definition: threadidledefault.c:44
The idle thread stack size in bytes.
