RTEMS 6.1
Data Structures | Macros | Typedefs | Enumerations | Functions
tftpfs_udp_network_fake.h File Reference
This header file provides interfaces and functions used to implement the UDP network fake for tftpfs tests. More...
#include <stddef.h>
#include <stdint.h>
#include <stdbool.h>
#include <sys/types.h>
struct  Tftp_Action
struct  Tftp_Interaction
struct  Tftp_Packet
#define _TFTPFS_UDP_NETWORK_FAKE_H
#define TFTP_STD_PORT   69
#define TFTP_MAX_IP_ADDR_STRLEN   (16 * 2 + 7 + 1)
#define TFTP_MAX_ERROR_STRLEN   20
#define TFTP_MAX_OPTIONS_SIZE   40
#define TFTP_KNOWN_IPV4_ADDR0_STR   "127.0.0.1"
 IP address strings and server names resolved by network fake functions like inet_aton() and gethostbyname().
#define TFTP_KNOWN_IPV4_ADDR0_ARRAY   127, 0, 0, 1
#define TFTP_KNOWN_SERVER0_NAME   "server.tftp"
#define TFTP_KNOWN_SERVER0_IPV4   "10.7.0.2"
#define TFTP_KNOWN_SERVER0_ARRAY   10, 7, 0, 2
#define TFTP_FIRST_FD   33333
 The faked socket() function (i.e. socket interaction) must return a file descriptor equal or larger than TFTP_FIRST_FD or -1.
#define TFTP_MODE_NETASCII   "netascii"
#define TFTP_MODE_OCTET   "octet"
#define TFTP_OPTION_BLKSIZE   "blksize"
#define TFTP_OPTION_TIMEOUT   "timeout"
#define TFTP_OPTION_TSIZE   "tsize"
#define TFTP_OPTION_WINDOWSIZE   "windowsize"
#define TFTP_WINDOW_SIZE_MIN   1
#define TFTP_BLOCK_SIZE_MIN   8
#define TFTP_BLOCK_SIZE_MAX   65464
typedef enum Tftp_Action_kind Tftp_Action_kind
typedef struct Tftp_Action Tftp_Action
typedef bool(* Tftp_Interaction_fn) (Tftp_Action *act, void *data)
 Carry out interactions with TFTP client.
typedef struct Tftp_Interaction Tftp_Interaction
typedef enum Tftp_Opcode Tftp_Opcode
typedef enum Tftp_Error_code Tftp_Error_code
typedef struct Tftp_Packet Tftp_Packet
enum  Tftp_Action_kind {
  TFTP_IA_KIND_SOCKET , TFTP_IA_KIND_CLOSE , TFTP_IA_KIND_BIND , TFTP_IA_KIND_SENDTO ,
  TFTP_IA_KIND_RECVFROM
enum  Tftp_Opcode {
  TFTP_OPCODE_RRQ = 1 , TFTP_OPCODE_WRQ = 2 , TFTP_OPCODE_DATA = 3 , TFTP_OPCODE_ACK = 4 ,
  TFTP_OPCODE_ERROR = 5 , TFTP_OPCODE_OACK = 6
enum  Tftp_Error_code {
  TFTP_ERROR_CODE_NOT_DEFINED = 0 , TFTP_ERROR_CODE_NOT_FOUND = 1 , TFTP_ERROR_CODE_NO_ACCESS = 2 , TFTP_ERROR_CODE_DISK_FULL = 3 ,
  TFTP_ERROR_CODE_ILLEGAL = 4 , TFTP_ERROR_CODE_UNKNOWN_ID = 5 , TFTP_ERROR_CODE_FILE_EXISTS = 6 , TFTP_ERROR_CODE_NO_USER = 7 ,
  TFTP_ERROR_CODE_OPTION_NEGO = 8
void _Tftp_Reset (void)
 Initialize and free the singleton control object.
void * _Tftp_Append_interaction (Tftp_Action_kind kind, Tftp_Interaction_fn fn, size_t size)
 Create an interaction and append it to the sequence of expected interactions.
bool _Tftp_Has_no_more_interactions (void)
 Have all queued interactions been processed?
const char * _Tftp_Get_error_str (uint16_t error_code)
 Provides a human readable description for an error code from an TFTP error packet.
Definitions and declarations of data structures and functions.
