RTEMS 6.1
Macros | Functions
tftpfs_interactions.h File Reference
This header file provides functions used to implement network interactions of the UDP network fake for tftpfs tests. More...
#define NO_BLOCK_SIZE_OPTION   0
#define NO_WINDOW_SIZE_OPTION   0
#define DO_NOT_WAIT_FOR_ANY_TIMEOUT   UINT32_MAX
void _Tftp_Add_interaction_socket (int domain, int type, int protocol, int result)
void _Tftp_Add_interaction_close (int fd, int result)
void _Tftp_Add_interaction_bind (int fd, int family, int result)
void _Tftp_Add_interaction_send_rrq (int fd, const char *filename, uint16_t dest_port, const char *dest_addr_str, uint16_t block_size, uint16_t window_size, bool result)
void _Tftp_Add_interaction_send_wrq (int fd, const char *filename, uint16_t dest_port, const char *dest_addr_str, uint16_t block_size, uint16_t window_size, bool result)
void _Tftp_Add_interaction_send_ack (int fd, uint16_t block_num, uint16_t dest_port, const char *dest_addr_str, bool result)
void _Tftp_Add_interaction_send_data (int fd, uint16_t block_num, size_t start, size_t len, uint8_t(*get_data)(size_t pos), uint16_t dest_port, const char *dest_addr_str, bool result)
void _Tftp_Add_interaction_send_error (int fd, uint16_t error_code, uint16_t dest_port, const char *dest_addr_str, bool result)
void _Tftp_Add_interaction_recv_data (int fd, uint32_t timeout_ms, uint16_t src_port, const char *src_addr_str, uint16_t block_num, size_t start, size_t len, uint8_t(*get_data)(size_t pos), bool result)
void _Tftp_Add_interaction_recv_ack (int fd, uint32_t timeout_ms, uint16_t src_port, const char *src_addr_str, uint16_t block_num, bool result)
void _Tftp_Add_interaction_recv_oack (int fd, uint32_t timeout_ms, uint16_t src_port, const char *src_addr_str, const char *options, size_t options_size, bool result)
void _Tftp_Add_interaction_recv_error (int fd, uint32_t timeout_ms, uint16_t src_port, const char *src_addr_str, uint16_t error_code, const char *err_msg, bool result)
void _Tftp_Add_interaction_recv_raw (int fd, uint32_t timeout_ms, uint16_t src_port, const char *src_addr_str, size_t len, const uint8_t *bytes, bool result)
void _Tftp_Add_interaction_recv_nothing (int fd, uint32_t timeout_ms)
Definitions and declarations of data structures and functions.
