RTEMS 6.1
This source file contains the implementation of the Trivial File Transfer Protocol (TFTP) file system. More...
#include <stdio.h>#include <stdlib.h>#include <inttypes.h>#include <errno.h>#include <malloc.h>#include <string.h>#include <unistd.h>#include <fcntl.h>#include <rtems.h>#include <rtems/libio_.h>#include <rtems/seterr.h>#include <rtems/tftp.h>#include <rtems/thread.h>#include "tftp_driver.h"Data Structures | |
| struct | tftpfs_info_s |
| #define | TFTPFS_VERBOSE (1 << 0) |
| #define | tftpfs_info_mount_table(_mt) ((tftpfs_info_t*) ((_mt)->fs_info)) |
| #define | tftpfs_info_pathloc(_pl) ((tftpfs_info_t*) ((_pl)->mt_entry->fs_info)) |
| #define | tftpfs_info_iop(_iop) (tftpfs_info_pathloc (&((_iop)->pathinfo))) |
Typedefs | |
| typedef struct tftpfs_info_s | tftpfs_info_t |
| ssize_t | _Tftpfs_Parse_options (const char *option_str, tftp_net_config *tftp_config, uint32_t *flags) |
| int | rtems_tftpfs_initialize (rtems_filesystem_mount_table_entry_t *mt_entry, const void *data) |
| Do not call directly, use mount(). | |
The code in this file handles the file system operations (such as mount(), open(), read(), write(), close() etc.). The networking part, i.e. the actual Trivial File Transfer Protocol implementation, is realized in another file - the TFTP client library.
