RTEMS 6.1
Data Structures | Enumerations | Functions
#include <rtems/test.h>
struct  RtemsStatusReqText_Entry
struct  RtemsStatusReqText_Context
 Test context for spec:/rtems/status/req/text test case. More...
enum  RtemsStatusReqText_Pre_Code {
  RtemsStatusReqText_Pre_Code_AlreadySuspended , RtemsStatusReqText_Pre_Code_CalledFromIsr , RtemsStatusReqText_Pre_Code_IllegalOnRemoteObject , RtemsStatusReqText_Pre_Code_IllegalOnSelf ,
  RtemsStatusReqText_Pre_Code_IncorrectState , RtemsStatusReqText_Pre_Code_InternalError , RtemsStatusReqText_Pre_Code_Interrupted , RtemsStatusReqText_Pre_Code_InvalidAddress ,
  RtemsStatusReqText_Pre_Code_InvalidClock , RtemsStatusReqText_Pre_Code_InvalidId , RtemsStatusReqText_Pre_Code_InvalidName , RtemsStatusReqText_Pre_Code_InvalidNode ,
  RtemsStatusReqText_Pre_Code_InvalidNumber , RtemsStatusReqText_Pre_Code_InvalidPriority , RtemsStatusReqText_Pre_Code_InvalidSize , RtemsStatusReqText_Pre_Code_IoError ,
  RtemsStatusReqText_Pre_Code_MpNotConfigured , RtemsStatusReqText_Pre_Code_NoMemory , RtemsStatusReqText_Pre_Code_NotConfigured , RtemsStatusReqText_Pre_Code_NotDefined ,
  RtemsStatusReqText_Pre_Code_NotImplemented , RtemsStatusReqText_Pre_Code_NotOwnerOfResource , RtemsStatusReqText_Pre_Code_ObjectWasDeleted , RtemsStatusReqText_Pre_Code_ProxyBlocking ,
  RtemsStatusReqText_Pre_Code_ResourceInUse , RtemsStatusReqText_Pre_Code_Successful , RtemsStatusReqText_Pre_Code_TaskExitted , RtemsStatusReqText_Pre_Code_Timeout ,
  RtemsStatusReqText_Pre_Code_TooMany , RtemsStatusReqText_Pre_Code_Unsatisfied , RtemsStatusReqText_Pre_Code_NotAStatusCode , RtemsStatusReqText_Pre_Code_NA
enum  RtemsStatusReqText_Post_Result {
  RtemsStatusReqText_Post_Result_AlreadySuspended , RtemsStatusReqText_Post_Result_CalledFromIsr , RtemsStatusReqText_Post_Result_IllegalOnRemoteObject , RtemsStatusReqText_Post_Result_IllegalOnSelf ,
  RtemsStatusReqText_Post_Result_IncorrectState , RtemsStatusReqText_Post_Result_InternalError , RtemsStatusReqText_Post_Result_Interrupted , RtemsStatusReqText_Post_Result_InvalidAddress ,
  RtemsStatusReqText_Post_Result_InvalidClock , RtemsStatusReqText_Post_Result_InvalidId , RtemsStatusReqText_Post_Result_InvalidName , RtemsStatusReqText_Post_Result_InvalidNode ,
  RtemsStatusReqText_Post_Result_InvalidNumber , RtemsStatusReqText_Post_Result_InvalidPriority , RtemsStatusReqText_Post_Result_InvalidSize , RtemsStatusReqText_Post_Result_IoError ,
  RtemsStatusReqText_Post_Result_MpNotConfigured , RtemsStatusReqText_Post_Result_NoMemory , RtemsStatusReqText_Post_Result_NotConfigured , RtemsStatusReqText_Post_Result_NotDefined ,
  RtemsStatusReqText_Post_Result_NotImplemented , RtemsStatusReqText_Post_Result_NotOwnerOfResource , RtemsStatusReqText_Post_Result_ObjectWasDeleted , RtemsStatusReqText_Post_Result_ProxyBlocking ,
  RtemsStatusReqText_Post_Result_ResourceInUse , RtemsStatusReqText_Post_Result_Successful , RtemsStatusReqText_Post_Result_TaskExitted , RtemsStatusReqText_Post_Result_Timeout ,
  RtemsStatusReqText_Post_Result_TooMany , RtemsStatusReqText_Post_Result_Unsatisfied , RtemsStatusReqText_Post_Result_NotAStatusCode , RtemsStatusReqText_Post_Result_NA
 T_TEST_CASE_FIXTURE (RtemsStatusReqText, &RtemsStatusReqText_Fixture)
