RTEMS 6.1
This source file contains the implementation of the RTEMS objects test support. More...
#include "t-test-rtems.h"#include <rtems/test.h>#include <inttypes.h>#include <rtems/score/threadimpl.h>Functions | |
| T_thread_timer_state | T_get_thread_timer_state (uint32_t id) |
| Objects_Maximum | T_objects_count (Objects_APIs api, uint16_t cls) |
| void | T_objects_check (Objects_APIs api, uint16_t cls, Objects_Maximum *expected, const char *name) |
| void | T_check_rtems_barriers (T_event event, const char *name) |
| void | T_check_rtems_extensions (T_event event, const char *name) |
| void | T_check_rtems_message_queues (T_event event, const char *name) |
| void | T_check_rtems_partitions (T_event event, const char *name) |
| void | T_check_rtems_periods (T_event event, const char *name) |
| void | T_check_rtems_regions (T_event event, const char *name) |
| void | T_check_rtems_semaphores (T_event event, const char *name) |
| void | T_check_rtems_tasks (T_event event, const char *name) |
| void | T_check_rtems_timers (T_event event, const char *name) |
| void * | T_seize_objects (rtems_status_code(*create)(void *, uint32_t *), void *arg) |
| void | T_surrender_objects (void **objects_p, rtems_status_code(*delete)(uint32_t)) |
