RTEMS 6.1
sysexits.h
1/*
2 * Copyright (c) 1987, 1993
3 * The Regents of the University of California. All rights reserved.
4 *
5 * Redistribution and use in source and binary forms, with or without
6 * modification, are permitted provided that the following conditions
7 * are met:
8 * 1. Redistributions of source code must retain the above copyright
9 * notice, this list of conditions and the following disclaimer.
10 * 2. Redistributions in binary form must reproduce the above copyright
11 * notice, this list of conditions and the following disclaimer in the
12 * documentation and/or other materials provided with the distribution.
13 * 3. Neither the name of the University nor the names of its contributors
14 * may be used to endorse or promote products derived from this software
15 * without specific prior written permission.
16 *
17 * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
18 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20 * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
21 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
22 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
23 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
24 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
25 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
26 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
27 * SUCH DAMAGE.
28 *
29 * @(#)sysexits.h 8.1 (Berkeley) 6/2/93
30 *
31 * $FreeBSD: release/9.1.0/include/sysexits.h 203964 2010-02-16 19:39:50Z imp $
32 */
33
34#ifndef _SYSEXITS_H_
35#define _SYSEXITS_H_
36
37/*
38 * SYSEXITS.H -- Exit status codes for system programs.
39 *
40 * This include file attempts to categorize possible error
41 * exit statuses for system programs, notably delivermail
42 * and the Berkeley network.
43 *
44 * Error numbers begin at EX__BASE to reduce the possibility of
45 * clashing with other exit statuses that random programs may
46 * already return. The meaning of the codes is approximately
47 * as follows:
48 *
49 * EX_USAGE -- The command was used incorrectly, e.g., with
50 * the wrong number of arguments, a bad flag, a bad
51 * syntax in a parameter, or whatever.
52 * EX_DATAERR -- The input data was incorrect in some way.
53 * This should only be used for user's data & not
54 * system files.
55 * EX_NOINPUT -- An input file (not a system file) did not
56 * exist or was not readable. This could also include
57 * errors like "No message" to a mailer (if it cared
58 * to catch it).
59 * EX_NOUSER -- The user specified did not exist. This might
60 * be used for mail addresses or remote logins.
61 * EX_NOHOST -- The host specified did not exist. This is used
62 * in mail addresses or network requests.
63 * EX_UNAVAILABLE -- A service is unavailable. This can occur
64 * if a support program or file does not exist. This
65 * can also be used as a catchall message when something
66 * you wanted to do doesn't work, but you don't know
67 * why.
68 * EX_SOFTWARE -- An internal software error has been detected.
69 * This should be limited to non-operating system related
70 * errors as possible.
71 * EX_OSERR -- An operating system error has been detected.
72 * This is intended to be used for such things as "cannot
73 * fork", "cannot create pipe", or the like. It includes
74 * things like getuid returning a user that does not
75 * exist in the passwd file.
76 * EX_OSFILE -- Some system file (e.g., /etc/passwd, /etc/utmp,
77 * etc.) does not exist, cannot be opened, or has some
78 * sort of error (e.g., syntax error).
79 * EX_CANTCREAT -- A (user specified) output file cannot be
80 * created.
81 * EX_IOERR -- An error occurred while doing I/O on some file.
82 * EX_TEMPFAIL -- temporary failure, indicating something that
83 * is not really an error. In sendmail, this means
84 * that a mailer (e.g.) could not create a connection,
85 * and the request should be reattempted later.
86 * EX_PROTOCOL -- the remote system returned something that
87 * was "not possible" during a protocol exchange.
88 * EX_NOPERM -- You did not have sufficient permission to
89 * perform the operation. This is not intended for
90 * file system problems, which should use NOINPUT or
91 * CANTCREAT, but rather for higher level permissions.
92 */
93
94#define EX_OK 0 /* successful termination */
95
96#define EX__BASE 64 /* base value for error messages */
97
98#define EX_USAGE 64 /* command line usage error */
99#define EX_DATAERR 65 /* data format error */
100#define EX_NOINPUT 66 /* cannot open input */
101#define EX_NOUSER 67 /* addressee unknown */
102#define EX_NOHOST 68 /* host name unknown */
103#define EX_UNAVAILABLE 69 /* service unavailable */
104#define EX_SOFTWARE 70 /* internal software error */
105#define EX_OSERR 71 /* system error (e.g., can't fork) */
106#define EX_OSFILE 72 /* critical OS file missing */
107#define EX_CANTCREAT 73 /* can't create (user) output file */
108#define EX_IOERR 74 /* input/output error */
109#define EX_TEMPFAIL 75 /* temp failure; user is invited to retry */
110#define EX_PROTOCOL 76 /* remote error in protocol */
111#define EX_NOPERM 77 /* permission denied */
112#define EX_CONFIG 78 /* configuration error */
113
114#define EX__MAX 78 /* maximum listed value */
115
116#endif /* !_SYSEXITS_H_ */
