RTEMS 6.1
RTEMS File Sysyem Path Eval Support. More...
| void | rtems_filesystem_eval_path_continue (rtems_filesystem_eval_path_context_t *ctx) |
| rtems_filesystem_location_info_t * | rtems_filesystem_eval_path_start_with_root_and_current (rtems_filesystem_eval_path_context_t *ctx, const char *path, size_t pathlen, int eval_flags, rtems_filesystem_global_location_t *const *global_root_ptr, rtems_filesystem_global_location_t *const *global_current_ptr) |
| rtems_filesystem_location_info_t * | rtems_filesystem_eval_path_start (rtems_filesystem_eval_path_context_t *ctx, const char *path, int eval_flags) |
| rtems_filesystem_location_info_t * | rtems_filesystem_eval_path_start_with_parent (rtems_filesystem_eval_path_context_t *ctx, const char *path, int eval_flags, rtems_filesystem_location_info_t *parentloc, int parent_eval_flags) |
| void | rtems_filesystem_eval_path_recursive (rtems_filesystem_eval_path_context_t *ctx, const char *path, size_t pathlen) |
| void | rtems_filesystem_eval_path_error (rtems_filesystem_eval_path_context_t *ctx, int eno) |
| void | rtems_filesystem_eval_path_cleanup (rtems_filesystem_eval_path_context_t *ctx) |
| void | rtems_filesystem_eval_path_cleanup_with_parent (rtems_filesystem_eval_path_context_t *ctx, rtems_filesystem_location_info_t *parentloc) |
| void | rtems_filesystem_eval_path_restart (rtems_filesystem_eval_path_context_t *ctx, rtems_filesystem_global_location_t **newstartloc_ptr) |
| Requests a path evaluation restart. | |
