volatile uint16_t | _res0 |
volatile uint16_t | fnr |
volatile uint16_t | _res1 |
volatile uint16_t | fnmr |
volatile uint16_t | _res2 |
volatile uint16_t | rfmr |
volatile uint16_t | _res3 |
volatile uint16_t | rfmmr |
volatile uint8_t | _res4 [3] |
volatile uint8_t | far |
volatile uint32_t | asr |
volatile uint32_t | drr1 |
volatile uint32_t | drr2 |
volatile uint16_t | _res5 |
volatile uint16_t | specr |
volatile uint16_t | _res6 |
volatile uint16_t | ep0sr |
volatile uint32_t | iep0cfg |
volatile uint32_t | oep0cfg |
volatile uint32_t | ep1cfg |
volatile uint32_t | ep2cfg |
volatile uint32_t | ep3cfg |
volatile uint32_t | ep4cfg |
volatile uint32_t | ep5cfg |
volatile uint32_t | ep6cfg |
volatile uint32_t | ep7cfg |
volatile uint32_t | ep0ctl |
volatile uint16_t | _res7 |
volatile uint16_t | ep1ctl |
volatile uint16_t | _res8 |
volatile uint16_t | ep2ctl |
volatile uint16_t | _res9 |
volatile uint16_t | ep3ctl |
volatile uint16_t | _res10 |
volatile uint16_t | ep4ctl |
volatile uint16_t | _res11 |
volatile uint16_t | ep5ctl |
volatile uint16_t | _res12 |
volatile uint16_t | ep6ctl |
volatile uint16_t | _res13 |
volatile uint16_t | ep7ctl |
volatile uint32_t | ep0isr |
volatile uint16_t | _res14 |
volatile uint16_t | ep1isr |
volatile uint16_t | _res15 |
volatile uint16_t | ep2isr |
volatile uint16_t | _res16 |
volatile uint16_t | ep3isr |
volatile uint16_t | _res17 |
volatile uint16_t | ep4isr |
volatile uint16_t | _res18 |
volatile uint16_t | ep5isr |
volatile uint16_t | _res19 |
volatile uint16_t | ep6isr |
volatile uint16_t | _res20 |
volatile uint16_t | ep7isr |
volatile uint32_t | ep0imr |
volatile uint16_t | _res21 |
volatile uint16_t | ep1imr |
volatile uint16_t | _res22 |
volatile uint16_t | ep2imr |
volatile uint16_t | _res23 |
volatile uint16_t | ep3imr |
volatile uint16_t | _res24 |
volatile uint16_t | ep4imr |
volatile uint16_t | _res25 |
volatile uint16_t | ep5imr |
volatile uint16_t | _res26 |
volatile uint16_t | ep6imr |
volatile uint16_t | _res27 |
volatile uint16_t | ep7imr |
volatile uint32_t | ep0dr |
volatile uint32_t | ep1dr |
volatile uint32_t | ep2dr |
volatile uint32_t | ep3dr |
volatile uint32_t | ep4dr |
volatile uint32_t | ep5dr |
volatile uint32_t | ep6dr |
volatile uint32_t | ep7dr |
volatile uint16_t | _res28 |
volatile uint16_t | ep0dpr |
volatile uint16_t | _res29 |
volatile uint16_t | ep1dpr |
volatile uint16_t | _res30 |
volatile uint16_t | ep2dpr |
volatile uint16_t | _res31 |
volatile uint16_t | ep3dpr |
volatile uint16_t | _res32 |
volatile uint16_t | ep4dpr |
volatile uint16_t | _res33 |
volatile uint16_t | ep5dpr |
volatile uint16_t | _res34 |
volatile uint16_t | ep6dpr |
volatile uint16_t | _res35 |
volatile uint16_t | ep7dpr |
