RTEMS 6.1
sd_card_driver_entry Struct Reference
const char * device_name
rtems_device_minor_number bus
rtems_libi2c_tfr_mode_t transfer_mode
uint8_t command [SD_CARD_COMMAND_SIZE]
uint8_t response [SD_CARD_COMMAND_SIZE]
int response_index
uint32_t n_ac_max
uint32_t block_number
uint32_t block_size
uint32_t block_size_shift
bool busy
bool verbose
bool schedule_if_busy
uint32_t retries
