RTEMS 6.1
#include <rtems-debugger-target.h>
Data Fields | |
| int | capabilities |
| size_t | reg_num |
| const size_t * | reg_offset |
| const uint8_t * | breakpoint |
| size_t | breakpoint_size |
| rtems_debugger_block | swbreaks |
| rtems_debugger_target_code_writer | code_writer |
| bool | memory_access |
| jmp_buf | access_return |
| uintptr_t | step_bp_address |
| rtems_id | step_tid |
The target data.
reg_offset: Table of size_t offset of a register in the register table. The table has one more entry than reg_num where the last entry is the size of the register table.
