volatile uint32_t | cs0_bnds |
uint8_t | reserved0_2004 [0x02008-0x02004] |
volatile uint32_t | cs1_bnds |
uint8_t | reserved0_200C [0x02010-0x0200C] |
volatile uint32_t | cs2_bnds |
uint8_t | reserved0_2014 [0x02018-0x02014] |
volatile uint32_t | cs3_bnds |
uint8_t | reserved0_201C [0x02080-0x0201C] |
volatile uint32_t | cs0_config |
volatile uint32_t | cs1_config |
volatile uint32_t | cs2_config |
volatile uint32_t | cs3_config |
uint8_t | reserved0_2090 [0x02100-0x02090] |
volatile uint32_t | timing_cfg_3 |
volatile uint32_t | timing_cfg_0 |
volatile uint32_t | timing_cfg_1 |
volatile uint32_t | timing_cfg_2 |
volatile uint32_t | ddr_sdram_cfg |
volatile uint32_t | ddr_sdram_cfg_2 |
volatile uint32_t | ddr_sdram_mode |
volatile uint32_t | ddr_sdram_mode_2 |
volatile uint32_t | ddr_sdram_md_cntl |
volatile uint32_t | ddr_sdram_interval |
volatile uint32_t | ddr_data_init |
uint8_t | reserved0_212C [0x02130-0x0212C] |
volatile uint32_t | ddr_sdram_clk_cntl |
uint8_t | reserved0_2134 [0x02148-0x02134] |
volatile uint32_t | ddr_init_address |
uint8_t | reserved0_214C [0x02BF8-0x0214C] |
volatile uint32_t | ddr_ip_rev1 |
volatile uint32_t | ddr_ip_rev2 |
uint8_t | reserved0_2C00 [0x02E00-0x02C00] |
volatile uint32_t | data_err_inject_hi |
volatile uint32_t | data_err_inject_lo |
volatile uint32_t | ecc_err_inject |
uint8_t | reserved0_2E0C [0x02E20-0x02E0C] |
volatile uint32_t | capture_data_hi |
volatile uint32_t | capture_data_lo |
volatile uint32_t | capture_ecc |
uint8_t | reserved0_2E2C [0x02E40-0x02E2C] |
volatile uint32_t | err_detect |
volatile uint32_t | err_disable |
volatile uint32_t | err_int_en |
volatile uint32_t | capture_attributes |
volatile uint32_t | capture_address |
uint8_t | reserved0_2E54 [0x02E58-0x02E54] |
volatile uint32_t | err_sbe |
uint8_t | reserved0_2E5C [0x2F00-0x2E5C] |
