RTEMS 6.1
interaction_data_recvfrom Struct Reference
int fd
uint32_t timeout_ms
uint16_t src_port
char src_addr_str [TFTP_MAX_IP_ADDR_STRLEN]
bool result
union {
   struct {
      uint16_t   block_num
   }   ack
   struct {
      size_t   options_size
      char   options [TFTP_MAX_OPTIONS_SIZE]
   }   oack
   struct {
      uint16_t   block_num
      size_t   start
      size_t   len
      uint8_t(*   get_data )(size_t pos)
   }   data
   struct {
      uint16_t   error_code
      char   err_msg [TFTP_MAX_ERROR_STRLEN]
   }   error
   struct {
      size_t   len
      uint8_t   bytes [0]
   }   raw
content
